Forum: µC & Digital Electronics MicroC OS-II
von mti578 (Guest)
I'm trying to get MicroC/OS-II version 2.52 running on a ATxmega128A1.
But I keep getting linker errors and I don't know what else I could do
to fix them.
Here is the Linker Output:
avr-gcc -mmcu=atxmega128a1 -Wl,-Map=microC.map os_core.o os_flag.o
os_mbox.o os_mem.o os_mutex.o os_q.o os_sem.o os_task.o os_time.o
os_cpu_a.o os_cpu_c.o TEST.o     -o microC.elf
TEST.o: In function `Task2(void*)':
C:\Documents and Settings\mti578\My
Documents\microC\default/../TEST.C:80: undefined reference to
`OSTimeDlyHMSM(unsigned char, unsigned char, unsigned char, unsigned
int)'
TEST.o: In function `Task1(void*)':
Documents\microC\default/../TEST.C:71: undefined reference to
int)'
TEST.o: In function `TaskStartCreateTasks':
Documents\microC\default/../TEST.C:56: undefined reference to
`OSTaskCreate(void (*)(void*), void*, unsigned char*, unsigned char)'
Documents\microC\default/../TEST.C:57: undefined reference to
TEST.o: In function `TaskStart(void*)':
Documents\microC\default/../TEST.C:50: undefined reference to
int)'
TEST.o: In function `main':
Documents\microC\default/../TEST.C:20: undefined reference to `OSInit()'
Documents\microC\default/../TEST.C:24: undefined reference to
Documents\microC\default/../TEST.C:25: undefined reference to
`OSStart()'
make: *** [microC.elf] Error 1
Build failed with 8 errors and 26 warnings...
But the OSxxx() functions are defined in the header file "uCOS_II.H"
which is included in test.c.
And I'm building all the necessary .c files which include the
declarations(? My english ain't the best) for those functions.
I even checked the .map file and the links for those functions are in
that file. I attached the .map file.
I got the CPU-Port from micrium.com.
