Forum: ARM programming with GCC/GNU tools Vectored IRQ does not go to ISR in LPC2148.
Author: Amogh Prabhulkar (Company: slim gym enterprises) (amogh)
I am using GNU ARM C compiler from Raisonace(RIDE).
I have written code for LPC2148  that generate interrupt when Timer-1
match the register T1MR0.
ISR simply turn on LED on Port 1.
Problem is that Code come out of main loop but does not go to ISR.
I search a lot in the examples code and have used a lot but nothing
likes to work.
Do I need to make changes in Start-up code.
I have attached Startup code file.
#include<lpc21xx.h>
#define LED1  0x00000001;
#define LED2  0x00000002;
void delay(void);
void  TIMER1_IRQ(void)  _attribute_ ((interrupt("IRQ")));;
int main (void)
IO0DIR =0XFFFFFFFF;
IO0SET = LED2;
/*********************************** TIMER-0 SETUP
FORDELAY********************************/
VPBDIV = 0x02;                                  //DIVIDED CCLOCK BY TWO
T0CTCR = 0X00;                                  //SET COUNTER AS TIMER
T0MCR  = 0X06;                                  //TC REST ON MATCH
T0IR   = 0X00;                                  //CLEAR ALL INTERRUPT
T0PR   = 0X06;                                  //COUNTER CLOCK DIVIDED
BY 6=1MHz
/*********************************** TIMER-1 SETUP INTERRUPT AFTER
1SEC*******************************/
T1TCR  = 0X02;                                  //MAKE TC REST
T1CTCR = 0X00;                                  //SET COUNTER AS TIMER
T1MCR  = 0X03;                                  //INTERRUPT AND REST ON
MATCH
T1IR   = 0X00;                                  //CLEAR ALL INTERRUPT
T1PR   = 0X06;                                  //COUNTER CLOCK DIVIDED
BY 6=1MHz
T1MR0  = 1000000;                               //MATCH-0=1000
VICIntSelect = 0x00000000;                      //SET THE TIMER-1
MATCH-0 INTERRUPT AS IRQ
VICVectCntl0 = 0x00000025;                      //SET CHANNEL
VICVectAddr0 =(unsigned long)TIMER1_IRQ;        //LOCAD THE ADDRESS OF
ISR
VICIntEnable = 0x00000020;                      //ENABLE TIMER1
INTERRUPT
T1TCR =0X01;                                  //ENABLE TIMER-1
for(;;)
IO0SET = LED1;
delay();
IO0CLR = LED1;
delay();
/**************************************** End
Main**************************************************/
void delay(void)
T0MR0 = 250000;                                    //MATCH-0=250000
T0TCR = 0X01;                                      //TURN ON TIMER-0
while((T0TCR & 0X01)==0X01);                       //WAIT FOR TIMER
MATCH AND INTERRUPT FLAG SET
T0TCR = 0X00;                                      //TURN OFF AND RESET
TIMER-0
/********************************** INTERRUPT
SUBROUTINE**************************************/
IO0CLR = LED2;
T1IR  |=0X00000001;                                 //CLEAR MATCH-0
INTERRUPT
VICVectAddr =0X00000000;
T1TCR  = 0X01;                                      //TURN ON TIMER-0
