Forum: µC & Digital Electronics Processing data from usb stick / Realtime processing
Author: Johannes Kestel (spaceman_spiff)
Hello,
I want to control a milling machine by computer under Windows XP SP2 in
real time (For other reasons I cannot use Dos or Unix).
The amount of datapoint can be very large (up to GB).
So my idea was to store the data on a large USB Stick (not in real time)
and then read and process the data it with a controller in order to
generate the commands for the stepping motors (in realtime).
Is there any way I can do this? (PIC controllers prefered)
What hardware (Usb Stick + Interface to controller) can I use?
How can I realize a Communtication directly to the Controller via USB?
What about PC Drivers?
do you have any examples that I can try out myself?
thank you,
Spaceman Spiff
Author: jrmymllr jrmymllr (jrmymllr)
Many microcontrollers have USB interfaces, so it could easily read data
off the USB drive.  I haven't used USB yet, but I often use PIC and TI
ARM Cortex-M3 controllers and they both have it available.
Author: mizch (Guest)
Simply having an USB interface is not sufficient.  Most Controllers
equipped with an USB capability are slaves.  To read from USB mass
storage, you need host (or OTG) capabilities which require a lot more
than a simple slave device offers.
Depending on your speed requirements, I'd try an SD Card.  SD card
libraries are available for most µcontrollers and are much simpler to
interface than an USB thumb drive.
Author: usb (Guest)
You should have a look at STI100. Its an USB Interface, which can easily
be used for reading / writing data on a usb Stick.
Thank you for your replies!
do you mean this
http://www.elv.de/ELV-STI-100-Interface-fuuml;r-US...
discussed
Beitrag "USB-Stick-Interface STI 100"
the sti100 looks very promising but I need some time to try to think
about it.
I like the SD card Idea as well. Do you have an example?
I do not know if an USB interface to the controller would handle the
realtime problem. - a mass storage device would be better.
any other ideas, examples schematics, codes?
Author: Hartmut Semken (Guest)
Storage is one option.
I think you need to calculate your data rate first: how much data do you
need to read per second to control the machine?
If we are talking one GB per day its much different from one GB per
minute, right?
I would probably go for an SD card as well, provided that the interface
can handle it.
The SD interface comes in two flavors: simple, serial SPI and a much
faster 4-bit parallel variant. The typical library only implements the
serial variant.
Your actual problem I would probably address in a different manner:
- use one controller per axis
- use an SPI to feed data to the axis controllers from a machine
controller
- us a network interface to feed the data from the PC to the machine
controller.
Depending on speed requirements the controllers could be:
machine controller: pollin AVR net-IO
http://www.pollin.de/shop/dt/NjI5OTgxOTk-/Bausaetz...
or rather the Webmodule by Ulrich Radig
http://www.ulrichradig.de/home/index.php/avr/avr-webmodule
good starting points if speed requirements are not too high.
For higher data rates and larger memory buffers, I would consider a
"larger" controller like
http://www.embedded-projects.net/index.php?module=...
This can integrate the axis controllers as software (output to port pins
directly) or use separate controllers to create loop-control and
maintain precise timing.
The speed that the windows machine can transmit over Ethernet should be
fast enough on /average/, even though Windows can not provide
real-time behavior.
The machine controller can implement the buffer required to even-out the
average speed to a constant speed.
Again: depending on your data rate, a small buffer (such as the Atmega32
or 644 can provide with its internal RAM) may be sufficient, if a larger
buffer is required for evening out the Windows processing jitter, the
ARM controller with megabytes of space will be easier to fulfil the
requirements.
hope, this helps
hase
