Hi , I am trying to get OpenOCD to work with LPC2138 with a parallel port wiggler. H-JTAG(also works with giveio.sys) works perfectly with my setup , I need to set it with nTRST --> output inverted nSRST-->"no sysrst" TCK Speed MAX/1. I replicated this by using parport_cable wiggler_ntrst_inverted jtag_speed 8 in the openOCD_lpc2138_wiggler.cfg. When I try compiling and flashing I get : Programming with OPENOCD openocd_go_flash.cmd Info: openocd.c:93 main(): Open On-Chip Debugger (2007-09-05 09:00 CEST) Error: lpc2000.c:384 lpc2000_flash_bank_command(): unknown LPC2000 variant Error: flash.c:180 handle_flash_bank_command(): 'lpc2000' driver rejected flash bank at 0x00000000 Error: jtag.c:1301 jtag_examine_chain(): number of discovered devices in JTAG chain (2) doesn't match configuration (1) Error: jtag.c:1302 jtag_examine_chain(): check the config file and ensure proper JTAG communication (connections, speed, ...) Error: jtag.c:1440 jtag_init(): trying to validate configured JTAG chain anyway... Warning: arm7_9_common.c:734 arm7_9_assert_reset(): srst resets test logic, too Error: arm_jtag.c:38 arm_jtag_set_instr_error_handler(): setting the new JTAG instruction failed, debugging is likely to be broken Any newbie errors I am making ? Regards Thomas
As far as I know H-JTAG installs it's own direct port-access driver but I have not used H-JTAG since several months It seems that the configuration is outdated. "reject flash bank" does not look good. Could you try with a configuration files from the openocd target library: interface/parport.cfg and target/lpc2148.cfg? Also try to increase the debug-level.
Hello Martin, I am using your example from here : http://www.siwawi.arubi.uni-kl.de/avr_projects/arm... Let me try the configuration file from the source you mentioned. Thomas
Attached files:I managed to get get OpenOCD to flash the program for me,with a few issues. 1) JTAG cannot detect the board unless I manually reset the board once after power up.After this it works fine,till I power off the board.Then I need to do the "manual reset once",once again. 2) After loading the firmware in ROM ,the board executes the program ,but I get the following message : Programming with OPENOCD openocd_go_flash.bat Open On-Chip Debugger (2008-03-22 12:00 CET) svn: r520 URL: http://svn.berlios.de/svnroot/repos/openocd/trunk/ Info: jtag.c:1329 jtag_examine_chain(): JTAG device found: 0x4f1f0f0f (Manufacturer: 0x787, Part: 0xf1f0, Version: 0x4) Info: target.c:240 target_init_handler(): executing reset script 'openocd_lpc2148_flash.script' Info: options.c:50 configuration_output_handler(): dcc downloads are disabled User: target.c:784 target_arch_state(): target state: halted User: armv4_5.c:340 armv4_5_arch_state(): target halted in ARM state due to debug request, current mode: System cpsr: 0x8000005f pc: 0x0000103c Info: options.c:50 configuration_output_handler(): flash 'lpc2000' found at 0x00000000 Info: options.c:50 configuration_output_handler(): erased sectors 0 through 26 on flash bank 0 in 0.156250s Info: options.c:50 configuration_output_handler(): wrote 36488 byte from file main.bin in 3.640625s (9.787554 kb/s) Warning: arm7_9_common.c:724 arm7_9_poll(): DBGACK set, but the target did not end up in the halted stated 1 User: target.c:365 target_process_reset(): Timed out waiting for reset Press any key to continue . . . I then exit this using "Stop Tools".Meanwhile the program is already executing on the board I have attached the OpenOCD files from my setup.
Hi , Just managed to get OpenOCD working for debugging partially. i.e. I am able to single step through the code. Now my problem is when I read the value of a variable ( by parking the mouse over it) , I get : for example 741-data-evaluate-expression ptr 741^error,msg="Cannot access memory at address 0x40005660" Any suggestions on what I might be doing wrong ?
Did you try with the gdb command set mem inaccessible-by-default off ? See http://openocd.berlios.de/doc/html/GDB-and-OpenOCD... for further information.
I tried this : target remote localhost:3333 set mem inaccessible-by-default off monitor soft_reset_halt monitor sleep 500 monitor arm7_9 force_hw_bkpts enable symbol-file lpcspi.elf load thbreak main continue It now seems to work as expected.Will do more trials and revert back. Thanks for sharing your knowledge and the results of your efforts. Thomas
