Forum: ARM programming with GCC/GNU tools Is this C statement valid?
Author: jrmymllr jrmymllr (jrmymllr)
Is this code valid to test if "x" is equal to either condition?
if(x == (CONDITION1 || CONDITION2))
    //stuff
The compiler (Codesourcery GCC) seems to be ok with it, but is it
legal/reliable code?
Author: kbuchegg (Guest)
NO
if( ( x == CONDITION1 ) ||
    ( x == CONDITION2 ) )
Having said that:
It is valid in the sense, that it follows the language rules. But it
does not what you think it should do.
Author: Martin (Guest)
if ( (x == CONDITION1) || (x == CONDITION2) )
    //stuff
The 'stuff' section will be processed if one of the conditions is true.
Author: mano (Guest)
this
if(x == (CONDITION1 || CONDITION2)) {
    //stuff
is equal to this
if((x == CONDITION1) || (x == CONDITION2)) {
    //stuff
(only) when
BOOL x = YES;     // must be YES
BOOL CONDITION1 = ...;
BOOL CONDITION2 = ...;
Thanks to everyone for the lightning quick replies.  I've always used:
if( ( x == CONDITION1 ) || ( x == CONDITION2 ) )
but was hoping to use a #define to turn this:
if(x == CONDITION)
into what I proposed by doing something like:
#define CONDITION       (CONDITION1 || CONDITION2)
I'll just go through the code and modify each instance correctly :)
Author: Bruce Graham (Company: Wadia) (papabravo)
The double vertical bar "||" is a relational operator like "<" or ">".
The single vertical bar "|" is a bit-wise operator.  You can use the the
single vertical bar to do what you were trying to do in the original
post.  The bit-wise combination of constants will yield a constant that
can be used to test multiple conditions simultaneously.
Author: BrEin (Guest)
So, to answer your question "Is this C statement valid?":
Yes it is.
But it works differently like you expect.
The language C don't understand booleans.
It takes numbers to represent true or false.
false == 0;
true  != 0;  // common 1
Your statement:
    //stuff
checks first the statement within the parenthesizes.
It returns a 1 when CONDITION1 OR CONDITION2 is not 0.
Otherwise it returns a 0.
Then it checks x with the return value.
When x is 0 and both conditions are also 0 the equation returns a
1.
When x is 1 and at least one condition is not 0 the equation returns
a 1, too.
When the expression in the if-header is not 0 the if branch will be
executed. Otherwise not, of course.
All this does not hurt the rules of C.
____________________________
But you purpose was to check if x has the same value like CONDITION1
OR CONDITION2.
To do this you have to reorder your question.
Has x the same value like CONDITION1 OR has x the same value like
CONDITION2?
Therefore is the answer of kbuchegg and the others correct.
    //stuff
This expression returns a 1 when at least one of the statements within
the parenthesizes return a 1.
regards
BrEin
I hope this answer is not "overdressed" and I seam to be a squirt.
I thought the question was caused by missing some knowledge.
Sorry if not.
Author: Fabian Hoemcke (Company: Xiopia (NSN)) (brein)
What is right?
a 1?
or
an 1?
I serios don't know it? :D
Author: Klaus Wachtler (mfgkw)
The 1
Really?
"...it returns the 1..."????
there is only one 1
OK! Thanks!
Author: yalu (Guest)
Fabian Hoemcke write:
> What is right?
> a 1?
> or
> an 1?
Since 1 ("one") doesn't start with a spoken vowel, it's "a 1" and not
"an 1". But in this context
> ... the equation returns a 1.
I think it's better style to omit the article:
  ... the equation returns 1.
Klaus Wachtler write:
> there is only one 1
I have at least three of them. Would you like to see them?
        1          1          1    ;-)
SNCR
at least two of them are just copies.
Author: moi (Guest)
#define cond(x) (CONDITION1==x || CONDITION2==x)
by chance?
Thank you very much yalu!!!
webmaster@embdev.netContactAdvertising on EmbDev.net
