Attached files:Hi,I try to debug my code in ram.but after searching on the web for a
long time,I still can't figure it out.I use Sourcery G++ Lite Edition
,openocd and jlink on ubuntu 10.04.for the flash run,it work well.the
MCU is STM32F103VE
I download the start up code and link script from the web.I modify the
link script to something like this:
.isr_vector :
. = ALIGN(4);
KEEP(*(.isr_vector)) /* Startup code */
. = ALIGN(4);
} >RAM
/* for some STRx devices, the beginning of the startup code is
stored in the .flashtext section, which goes to FLASH */
.flashtext :
. = ALIGN(4);
*(.flashtext) /* Startup code */
. = ALIGN(4);
} >RAM
/* the program code is stored in the .text section, which goes to
Flash */
.text :
. = ALIGN(4);
*(.text .text.* .gnu.linkonce.t.*)
*(.plt)
*(.gnu.warning)
*(.glue_7t) *(.glue_7) *(.vfp11_veneer)
*(.ARM.extab* .gnu.linkonce.armextab.*)
*(.gcc_except_table)
} >RAM
please help.
and sorry for my poor English.
So far I have not tested "RAM-debugging" with STM32 controllers so these are just some hints which might be helpful: - In the Makefile there is a variable RUN_MODE which is set to FLASH_RUN in the file in the archiv. Set it to RAM_RUN. The stetting is later used to select the linker-script. Look into the output of make all and verify that the *_RAM linker-script is used. The content of RUN_MODE is also passed as a preprocessor definition so #ifdef RAM_RUN or #ifdef FLASH_RUN can be used in the source-code. - SystemInit_ExtMemCtl() is called in the reset handler, usually SystemInit should do. Initialisation of the external memory interface can be enabled by a preprocessor define (see system_stm32*.c). Since initialization of the external memory interface can be enabled in SystemInit() it might be better to call SystemInit in the reset-handler. This may not cause a problem but it might be better to use the method intended by the STM library-developers until everything starts up as expected. - I did not check every line in the linker-script for RAM but it looks o.k. - Since the .data output-section is already at the correct location it is o.k. to wrap the first for-loop (copy data seg initializers...) with #ifdef FLASH_RUN/#endif - MSP is already set in the reset-handler-function so there should be no need to add something for this. - Since the interrupt-vector-table is also in RAM and not at the default location the the beginning of the flash-memory area the location has do be configured in SCB's VTOR register before any interrupt is enabled. See function NVIC_SetVectorTable in misc.c. Call could be done in the reset-handler. - Since the core should start run the code in RAM, the debuggering-software should set the program-counter (PC) to the reset-handler's address. This can be done with OpenOCD just before a "resume".
Thank you very much for you reply I will try it later and report what I get. Thanks again.
Thank you Martin By following you instruction ,I finaly made it work ! 1.Modify the link script to put all the sections in ram 2.Set RUN_MODE to RAM_RUN in Makefile and make sure the linker link with the ram-run-link-script 3.Change the Reset_Handler to:
void Reset_Handler(void) { /* SCB's VTOR register to the correct interrupt-vector-table address in ram */ #ifdef RAM_RUN NVIC_SetVectorTable(NVIC_VectTab_RAM,0X0); #endif /* FSMC Bank1 NOR/SRAM3 is used for the STM3210E-EVAL, if another Bank is required, then adjust the Register Addresses */ SystemInit_ExtMemCtl(); /* restore original stack pointer */ asm(" LDR r0, =_estack"); asm(" MSR msp, r0"); /* Initialize data and bss */ __Init_Data(); /* Call the application's entry point.*/ main(); } |
4.Change __Init_Data to:
void __Init_Data(void) { unsigned long *pulSrc, *pulDest; #ifdef FLASH_RUN /* Copy the data segment initializers from flash to SRAM */ pulSrc = &_sidata; for(pulDest = &_sdata; pulDest < &_edata; ) { *(pulDest++) = *(pulSrc++); } #endif /* Zero fill the bss segment. */ for(pulDest = &_sbss; pulDest < &_ebss; ) { *(pulDest++) = 0; } } |
5.Use the following openocd command:
reset halt load_image PATH_TO_IMAGE 0x0 TYPE_OF_IMAGE reg pc 0x20000004 resume |
