good morning,
am obliged to define the type t_pnet_data before the architecture to be
able to use it in ports types, this is a part of the code :
library ieee;
use ieee.std_logic_1164.all;
subtype t_pnet_data is std_logic_vector(7 downto 0);
type net_frame is record
low : t_pnet_data;
high : t_pnet_data;
end record net_frame;
entity pnet_write is
port(
p_net_data_in : in std_logic_vector(7 downto 0);
p_net_data_valid : in std_logic;
p_net_data_read : out std_logic;
p_cpu_data_out : out std_logic_vector(7 downto 0);
p_cpu_data_valid : out std_logic;
p_cpu_data_read : in std_logic;
p_cpu_parity : out std_logic;
p_retx_data_out : out net_frame;
p_retx_data_valid : out std_logic;
p_retx_data_read : in std_logic
end pnet_write;
architecture write of pnet_write is
begin
and this the error :
** Error: C:/Modeltech_6.2d/examples/pnet_write.vhd(5): near "subtype":
expecting: ARCHITECTURE CONFIGURATION ENTITY LIBRARY PACKAGE USE
what can i do ?!
best regards
Wafa
You cannot define a type outside the entity- or architecture. When you need such a type, you have to define it in a package and "use" the package.
Create new file with
library ieee; use ieee.std_logic_1164.all; package my_data_types is subtype t_pnet_data is std_logic_vector(7 downto 0); type net_frame is record low : t_pnet_data; high : t_pnet_data; end record net_frame; end package my_data_types; |
In your design you write
library ieee; use ieee.std_logic_1164.all; use work.my_data_types.all; -- <-- your package in standard library work entity pnet_write is port( p_net_data_in : in std_logic_vector(7 downto 0); p_net_data_valid : in std_logic; p_net_data_read : out std_logic; p_cpu_data_out : out std_logic_vector(7 downto 0); p_cpu_data_valid : out std_logic; p_cpu_data_read : in std_logic; p_cpu_parity : out std_logic; p_retx_data_out : out net_frame; p_retx_data_valid : out std_logic; p_retx_data_read : in std_logic ); end pnet_write; |
To get more information, just type "vhdl package" in google ;)
