Forum: FPGA, VHDL & Verilog calling a process
Author: Wafa (Guest)
Good morning,
is it possible in an architecture to call a process several times only
by changing its variables ?!
for example, if i have a process called calculate
calculate:process(A,B,C)
 begin
C<=A+B;
end process calculate;
then i want to use the same process for D,E and F
is it possible to call calculate without writing the instructions again?
if its possible,how ?
best regards
Wafa
Author: Na sowas (Guest)
What you need is a function for calculate.
>  begin
>  C<=A+B;
You do not call a process.
The process above is sensitive on A, B and C.
These aren't variables but signals!
But for this here:
   begin
   C<=A+B;
you do not need a process at all. Write it down this way:
   C<=A+B;
Thats the concurrent style.
u didnt realy answer my question,  i know A B and C are signals,
 u said  i need a function , so how can i write this and call it for D E
and F  ?!
thank you
Because the question itself doen't make much sense...
In the process
calculate: process(A,B,C)
the Symbols A, B, and C are not parameters that are handed over to the
process. The are just flags, which say to recalculate the process on
every change of each of them.
function calculate (da : std_logic_vector, db : std_logic_vector)
                           return std_logic_vector is
  variable t : std_logic_vector := '0';
begin
  t := da + db;  -- higly dependent on libraries
  return t;
end calculate ;
  c <= calculate(a,b);
  f <= calculate(d,e);
But what about typing in the words function+vhdl into google?
On the other hand duplicating ressources can be done with a generate
statement or a loop.
Thank you realy much :)
Author: Bernd (Guest)
regarding functions in VHDL:
keep in mind that the output of synthesis tools has to be watched
carefully if you use high-level vhdl constructs like functions...
the output may in some cases be not very effective or not of that kind
as you expected
  • [vhdl]VHDL code[/vhdl]
webmaster@embdev.netContactAdvertising on EmbDev.net
