Hi Friends, I am from Turkey. I take VHDL lessons in my university and I have a term project for this lesson. In this project, I have 2 bit input and four n-bit register 4th register is a temporary register and when my two bit input is "00" my n-bit registers save their values. then it is "01" R2's value is copied into Temp register,then R1's value is copied to R2 register and Temp's value is copied into R1 register. when it is "10" same things happen between R1 and R3 register and lastly when it is "11" same things happen again R2 and R3 registers. I wrote all codes of my project but Some things goes wrong because if 2bit input changes when wrong time every register lose their values and maybe every register have one value I want to restart my shift register when 2 bit input changes. then if I change the 2 bit input it restart the give enable bits to my registers. I will paste my vhdl code below. Please give me some solutions. I tried to evade from this problem with writing this code:w is 2 bit input Regularstarting is used for the restart the registers enable inputs rglr:process(w,Clock) begin if w(0)'Event and w(0)='1' then Regularstarting<='1'; elsif w(1)'Event and w(1)='1' then Regularstarting<='1'; else Regularstarting<='0'; end if; end process; When I simulate this with Xilinx 9.2i there is no problem but if I click on the Synthesize then it gives error:( ERROR:Xst:827 - "C:/VHDL/XilinX/Proje/eightforty.vhd" line 160: Signal Regularstarting cannot be synthesized, bad synchronous description. --> I developed my code. when my registers swaping then it writes on the sevensegment it writes svap when swapping is done then is writes done. The data in the bus can be seen with dividing the clock(with changing number of bits of countforclk) this code is ready for every thing. I have only one problem the values of the registers can be lost if I change 2 bit input wrong time to evade this problem I have to restart enable inputs of registers This is my main code: library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; library work; use work.comps.all; ---- Uncomment the following library declaration if instantiating ---- any Xilinx primitives in this code. --library UNISIM; --use UNISIM.VComponents.all; entity eightforty is generic(M:integer: = ; Port ( Data :in STD_LOGIC_VECTOR(M-1 downto 0); Extern,Resetn : in STD_LOGIC; Clock : in STD_LOGIC; Deneme :out STD_LOGIC_VECTOR(2 downto 0); svnsgmnt:out STD_LOGIC_VECTOR(0 to 6); an1,an2,an3,an4:inout STD_LOGIC:='0'; w : in STD_LOGIC_VECTOR (1 downto 0); Buswires : inout STD_LOGIC_VECTOR (M-1 downto 0)); end eightforty; architecture Behavioral of eightforty is signal R1 :STD_LOGIC_VECTOR(M-1 downto 0):="00001001"; signal R2 :STD_LOGIC_VECTOR(M-1 downto 0):="11111111"; signal R3 :STD_LOGIC_VECTOR(M-1 downto 0):="11000000"; signal Temp :STD_LOGIC_VECTOR(M-1 downto 0):="00000000"; signal Q :STD_LOGIC_VECTOR(3 downto 1); signal countforsvn:STD_LOGIC_VECTOR(1 downto 0):="00"; signal countforclk:STD_LOGIC_VECTOR(3 downto 0):=(OTHERS=>'0'); signal Clock3hz:STD_LOGIC:='0'; signal Done :STD_LOGIC:='0'; signal Rin,Rout :STD_LOGIC_VECTOR(3 downto 1):="000"; signal Tempin,Tempout :STD_LOGIC; signal Regularstarting:STD_LOGIC:='0'; begin cnt4clk:process(Clock) begin if Clock'Event and Clock='1' then if Resetn='1' then countforclk<=(OTHERS=>'0'); else countforclk<=countforclk+1; end if; end if; end process cnt4clk; Clock3hz<=countforclk(3); cntr:process(clock) begin if Clock'Event and Clock='1' then countforsvn<=countforsvn+'1'; if countforsvn="00" then an1<='1'; an2<='0'; an3<='0'; an4<='0'; elsif countforsvn="01" then an1<='0'; an2<='1'; an3<='0'; an4<='0'; elsif countforsvn="10" then an1<='0'; an2<='0'; an3<='1'; an4<='0'; elsif countforsvn="11" then an1<='0'; an2<='0'; an3<='0'; an4<='1'; countforsvn<="00"; end if; end if; end process cntr; writetosvn:process(Clock) begin if Done='0' then if an1='1' then svnsgmnt<="0100100"; elsif an2='1' then svnsgmnt<="1100011"; elsif an3='1' then svnsgmnt<="0001000"; elsif an4='1' then svnsgmnt<="0011000"; else svnsgmnt<="0000000"; end if; elsif Done='1' then if an1='1' then svnsgmnt<="1000010"; elsif an2='1' then svnsgmnt<="1100010"; elsif an3='1' then svnsgmnt<="1101010"; elsif an4='1' then svnsgmnt<="0110000"; end if; end if; end process writetosvn; CntrlCrct:CntrlCrt generic map(K=>3) port map(Regularstarting,Clock3hz,Q); rglr:process(w,Clock) begin if w(0)'Event and w(0)='1' then Regularstarting<='1'; elsif w(1)'Event and w(1)='1' then Regularstarting<='1'; else Regularstarting<='0'; end if; end process; selection:process(w,Q) begin if w(1)='0' and w(0)='1' and Resetn='0' then Tempin<=Q(1); Rout(2)<=Q(1); Rin(2)<=Q(2); Rout(1)<=Q(2); Rin(1)<=Q(3); Tempout<=Q(3); Rout(3)<='0'; Rin(3)<='0'; elsif w(1)='1' and w(0)='0' and Resetn='0' then Tempin<=Q(1); Rout(3)<=Q(1); Rin(3)<=Q(2); Rout(1)<=Q(2); Rin(1)<=Q(3); Tempout<=Q(3); Rout(2)<='0'; Rin(2)<='0'; elsif w(1)='1' and w(0)='1' and Resetn='0' then Tempin<=Q(1); Rout(3)<=Q(1); Rin(3)<=Q(2); Rout(2)<=Q(2); Rin(2)<=Q(3); Tempout<=Q(3); Rout(1)<='0'; Rin(1)<='0'; else Rin(1)<=Q(1); Rout(1)<=Q(1); Rin(2)<=Q(2); Rout(2)<=Q(2); Rin(3)<=Q(3); Rout(3)<=Q(3); Tempin<='0'; Tempout<='0'; end if; end process selection; Done<=Q(3); Deneme(2)<=Q(1); Deneme(1)<=Q(2); Deneme(0)<=Q(3); loadtobus:process(Extern,Rout,Tempout,w) begin if Extern='1' then Buswires<=Data; elsif Rout(1)='1' then Buswires<=R1; elsif Rout(2)='1' then Buswires<=R2; elsif Rout(3)='1' then Buswires<=R3; elsif Tempout='1' then Buswires<=Temp; else Buswires<=(OTHERS=>'Z'); end if; end process loadtobus; loadtoregister:process(Rin,Tempin,Clock) begin if Rin(1)='1' then R1<=Buswires; elsif Rin(2)='1' then R2<=Buswires; elsif Rin(3)='1' then R3<=Buswires; elsif Tempin='1' then Temp<=Buswires; end if; end process loadtoregister; --firstdatain:TRIS generic map(N=>M) -- port map(Data,Extern,Buswires); -- --register1:registern generic map(N=>M) -- port map(Buswires,Rin(1),Clock,R1); -- --register2:registern generic map(N=>M) -- port map(Buswires,Rin(2),Clock,R2); -- --register3:registern generic map(N=>M) -- port map(Buswires,Rin(3),Clock,R3); -- --registertemp:registern generic map(N=>M) -- port map(Buswires,Tempin,Clock,Temp); -- --trist1:TRIS generic map(N=>M) -- port map(R1,Rout(1),Buswires); -- --trist2:TRIS generic map(N=>M) -- port map(R2,Rout(2),Buswires); -- --trist3:TRIS generic map(N=>M) -- port map(R3,Rout(3),Buswires); -- --tristemp:TRIS generic map(N=>M) -- port map(Temp,Tempout,Buswires); end Behavioral; And This my Shift register(3 bit shift register to sends enable Rins and Routs) library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; ---- Uncomment the following library declaration if instantiating ---- any Xilinx primitives in this code. --library UNISIM; --use UNISIM.VComponents.all; entity CntrlCrt is generic(K:integer:=4); Port ( Resetn,Clock: in STD_LOGIC; Q : inout STD_LOGIC_VECTOR (1 to K):="000"); end CntrlCrt; architecture Behavioral of CntrlCrt is signal counter1 :STD_LOGIC_VECTOR(1 downto 0):="00"; signal s:STD_LOGIC:='1'; begin process(Clock,Resetn) begin if Resetn = '1' then Q<=(OTHERS=>'0'); counter1<="10"; elsif Clock'EVENT and Clock ='1' then if counter1="10" then counter1<="00"; s<='1'; else counter1<=counter1+1; s<='0'; end if; shftbits:For i in 1 to K-1 loop Q(i)<=Q(i+1); end loop; Q(K)<=s; end if; end process; end Behavioral; Everything is wrote by me please do not copy without obtaining permission.
if w(0)'Event and w(0)='1' then Regularstarting<='1'; elsif w(1)'Event and w(1)='1' then Regularstarting<='1'; else Regularstarting<='0'; end if; Everything you describe must be able to be synthesized in FlipFlops an combinatorial logic. So Regularstarting is the output of a FF. But a usual FF has only one clock input and one data input. You describe a FF that should act on two clocks: w(0) and w(1). This is not synthesizeable... Additionally according to your description your signal Regularstarting will only be '1' exactly at the edge of the clocks. Otherwise you say, it must be '0'. But a edge of a signal has the time 0 fs. So your singal will be always '0'... :-o Your code is pretty unreadbale, because there are no indents to see blocks of code belonging to each other. Like that:
rocess(Clock,Resetn) begin if Resetn = '1' then Q<=(OTHERS=>'0'); counter1<="10"; elsif Clock'EVENT and Clock ='1' then if counter1="10" then counter1<="00"; s<='1'; else counter1<=counter1+1; s<='0'; end if; shftbits:For i in 1 to K-1 loop Q(i)<=Q(i+1); end loop; Q(K)<=s; end if; end process; |
BTW:
if Resetn = '1' then Q<=(OTHERS=>'0'); counter1<="10"; |
Resetn is the term for a low-actove reset signal. but your reset is high-active :-o
Thank you for your helping my friend:) but how can I restart when w input signal changes:( if I dont restart the shift register everything can be wrong:( I want to send a reset signal only one clock cycle when w input changes. I made the Reset input high-active because if I make low-active then I have to give 1 to reset signal when I make timing simulation. if any mistakes will be occur then I can change it. I will implement this circuit on the Xilinx Basys2
First you have to synchronize the w inputs to your system clock. Then
you can detect falling and rising edges on this signals simply by
checking transitions. See this examplelibrary ieee; use ieee.std_logic_1164.all; entity edge_detect is port (async_sig : in std_logic; clk : in std_logic; rise : out std_logic; fall : out std_logic ); end; architecture RTL of edge_detect is begin process variable sr : std_logic_vector (3 downto 0) := "0000"; begin -- the whole design is synchronous to THE ONE AND ONLY SYSTEM CLOCK wait until rising_edge(clk); -- detect edges rise <= not sr(3) and sr(2); fall <= not sr(2) and sr(3); -- take the input in the shift register sr := sr(2 downto 0) & async_sig; end process; end architecture; |
Thank you again my friend:) I wrote this code to ise 9.2i then I simulate it. Then I saw that the falling or rising edge detection is coming with some delay.I couldnt understand how does this code detect the edges of input signal. What do you think about this delay? Does it cause wrong processes or wrong swapping?
> Then I saw that the > falling or rising edge detection is coming with some delay. Correct. There are 4 clocks latency due to the shift register. See the value of the shift register:
time --> 0 1 2 3 4 5 6 7 8 9 10 ... input 0 0 0 0**1 1 1 1 1 1 1 sr(0) 0 0 0 0 0 1 1 1 1 1 1 sr(1) 0 0 0 0 0 0 1 1 1 1 1 sr(2) 0 0 0 0 0 0 0 *1* 1 1 1 sr(3) 0 0 0 0 0 0 0 *0* 1 1 1 |
** is the rising edge in the input signal.
and 4 clocks later the sr(3) is '0' and sr(2) is '1'.
And this is a rising edge:
No, it cauese a slichgt delay on async inputs. In real life this usually
is no problem: Switches, Keys, Sensors... are so slow that 4 clocks of
e.g. 50MHz does no harm to the signal.
Every uC does the syncing this way also.
Thank you for everything:) I will write some code again. Because w is changed by me so it can be change wrong time (for example swapping isnt done) if I change w when swappig isnt done then a signal will wait for the swapping done:) thank you again. I think this project is completed:)
