Forum: µC & Digital Electronics Executing code from offset addess in SRAM
Author: Vani Aithal (blquest)
Dear All,
We are using AT91SAM9263.We are trying to run our application in SRAM
from an offset address in RAM.
1. At the base address of the SRAM, bootloader is executing.
2. Bootloader copies the application to the RAM area to an address say
(Base Address + n)th location.
3. Then bootloader jumps to (Base Address + n)th location and executes
the application.
In this process. 3rd step is not working.Has any one did such
implementation on AT91SAM9263?
           OR
on any other controller such implementation has been done.
If so please please share the information.
Thanks a lot.
  Vani
Author: Reinhard Kern (Guest)
Hello,
the application must be compiled at the resulting address, or in other
words, there can be no offset - if you try to run it at address xxxx,
then you must compile/assemble/link it with org xxxx.
regards Reinhard
webmaster@embdev.netContactAdvertising on EmbDev.net
