Forum: ARM programming with GCC/GNU tools FIQ interrupt using asmfunc.S or startup.S
von Andre (Guest)
I'm using the interrupt.h and asmfunc.S included in SD card project from
Martin THOMAS website.
To use a IRQ interrupt i can use:
RegisterVector(EINT0_INT, EINT0_Routine, PRI_HIGHEST, CLASS_IRQ);
IrqEnable();
but for FIQ i don't know how can i doo that.
I've tried RegisterVector(EINT0_INT, EINT0_Routine, PRI_HIGHEST,
CLASS_FIQ);
FiqEnable();
but don't work.
Reading the interrupcao.h i find two procedures:
void LoadFiqRegs (long int *regs);
void StoreFiqRegs (long *regs);
I don't know how can i use this two procedures.
Anyone knows how can I use the FIQ interruption with this asmfunc.S?
von (prx) A. K. (prx)
The startup code in asmfunc.S does not support FIQ. The FIQ vector runs
into an infinite loop (Trap) and there is no stack assigned.
BTW: You did not mention the controller type.
von Andre (Guest)
I changed the asmfunc.S and use a FIQ interruption, but only enter the
procedure one time. I clean the flags of interruption but still don't
work;
I changed in the code:
.section .VECTOR, "ax"
.arm
  LDR  PC, [PC, #24]  @ Reset entry, jump to reset handler
  LDR  PC, [PC, #24]  @ Undef entry, trap
  LDR  PC, [PC, #24]  @ SWI entry, jump to SWI handler
  LDR  PC, [PC, #24]  @ PAbt entry, trap
  LDR  PC, [PC, #24]  @ DAbt entry, trap
  .word  0    @ Check sum (set by flash programmer)
  LDR  PC, [PC, #20]  @ IRQ entry, jump to IRQ handler
  LDR     PC, [PC, #20]  @ FIQ entry, trap
  .word  Reset_Handler  @ Reset handler
  .word  Trap    @ Undefined Instruction handler
  .word  SWI_Handler  @ Software Interrupt handler
  .word  Trap    @ Prefetch Abort handler
  .word  Trap    @ Data Abort handler
  .word  IRQ_Handler  @ IRQ handler
FIQ_Addr:  .word  FIQ_Routine
FIQDisable:
  MRS  R0, SPSR
  ORR  R0, R0, #B_Fiq
  MSR  SPSR_c, R0
  MOVS  PC, LR
FIQEnable:
  MRS  R0, SPSR
  BIC  R0, R0, #B_Fiq
  MSR  SPSR_c, R0
  MOVS  PC, LR
In my main function I set the Fiq interruption using:
  EXTMODE|=1<<0;
  EXTINT=0x1;
  VICIntSelect |= 0x00004000;
  VICIntEnable = 0x00004000;
  FiqEnable();
and start the while(1) loop that runs infinitaly.
When I press the button enter in the Interruptio routine:
void FIQ_Routine() {
  int k;
  //Força limpeza da interrupção (Caso de travamento)
  if ((EXTINT==1)&&(T0TC>=tempo+1000)) {
    EXTINT=0x1;
  //Pega o endereço da fonte de interrupção.
  k=EXTINT;
  //Verifica se foi Ext0 que interrompeu
  if(test_bit(k,0)) {
    LCD_limpaLinha(2,16);
    LCD_escreveMsgLC(2,1,"Botao apertado.");
    Timer0_espera(1000);
  tempo=T0TC;
  EXTINT=0x1;
The execution back to main while(1) loop but when I pressed the button
again the Interruption doesnt work anymore.
Anyone can help me to solve this?
An interrupt handler as defined by the machine is called in a different
way as normal C functions are. FIQ handlers too. Normal IRQs are wrapped
by the handler code in the asm file, so normal C functions can be used
as final IRQ handlers. Your FIQs however are called directly. When a C
function is called directly by hardware, the C function must be declared
accordingly:
 void FIQ_Routine () __attribute__ ((interrupt ("FIQ")));
You should also allocate some bytes for the FIQ stack. There is a
definition for the FIQ stack size in the asm file, which was set to 0 in
the version shown above.
Note that interrupts are intended to be fast and short, so slow LCD
functions should not be placed withing handlers. Especially if they can
interrupt some other LCD output sequence in main program, disturbing
state and pin control as well as timing. A simple LED as event indicator
for debugging (e.g. toggling) is much safer.
