Forum: ARM programming with GCC/GNU tools Problem with eclipse, yagarto and LPC2148 test project
Author: Max (Guest)
I wanted to check all settings of eclipse and yagarto with this LB2148
test project.
http://www.yagarto.de/howto/examples/index.html
I configured everything as it is described on yagarto.de. No changes
where done in the files of this project.
After making the project, I got the error:
Description  Resource  Path  Location  Type
make: *** [test_ram.elf] Error 1  LPC2148pro    line 0  C/C++ Problem
Where can be the problem?
I also checked some other projects and got the same error, so it should
be anywhere in the eclipse settings or ...?
I use yagarto from 23.12.2009 and eclipse is also the newest.
Possibly its a trivial error but I am very new to ARM and GCC tools.
Thank you
Max
Author: Shabnam Bozorgi (shbozorgi)
Hi Max,
I am in the same situation new and the same problem!
Could you sold it yet?
Thanks,
Shabnam
Hi again with good news:)
Problem solved! add a PATH variable C:\cygwin\bin it solves the problem
and add it in your project properties as well.
If you had any problem, we can solve it together.
Cheers,
Shabnam
