Forum: ARM programming with GCC/GNU tools S3C2440 on WINARM
von Andrew (Guest)
How do I configure WINARM to compile code for Samsung S3C2440?
Any example project is welcome.
Regards,
Andrew
von Clifford S. (clifford)
GCC is agnostic to any particular ARM microcontroller implementation;
what you specify is the ARM core in use.  For the Samsumg S3C2440 that
is ARM920T, so -mcpu=arm920t is the required compiler option.  Other ARM
specific options that you may find useful are detailed in the user
manual:
http://gcc.gnu.org/onlinedocs/gcc-4.4.3/gcc/ARM-Options.html#ARM-Options.
I do not believe that WinARM provides any ARM9 run-time start-up code
examples, so you will have to work on that yourself.  ARM9 is
considerably more complex that ARM7.  You will have to configure the
PLL, cache, MMU, and SDRAM controller as well as the normal C runtime
start-up of initialising the vector table, establishing a stack, static
data initialisation, static constructors (for C++), and invoking main().
Some of this will be board specific; specifically SDRAM timing
configuration.
I have used WinARM successfully on a custom S3C2440X board, so it can be
done, but you will need to understand the hardware and at least a little
assembler to develop your own start-up code.
ps:
If you use an off-the-shelf bootloader, you may find that it performs
much of the core initialisation for you so you will then only need a
fairly conventional C runtime start-up.
Also to get the most out of an ARM9 you will want to run from RAM; this
means that your runtime code will need to be linked to run from RAM, but
load from Flash.  There are a number of ways to achieve this, but again
you are largely on your own, or an existing bootloader may well help.
When I used it we had our own bootloader that decompressed the
application from Flash to RAM using zlib.  The RAM application image was
compressed at build time and a utility to generate an assembler data
array from a binary image was used the output from which was then
assembled and linked to a start-up stub that ran from flash and
performed the decompression then jumped to the start address.  During
the boot process, three separate C run-time environments were
established; bootloader; application decompression stub, then the
application itself.  It is simplest if the core initialisation is
performed once by the bootloader, although that need not be the case.
I also recommend that you have a JTAG hardware debugger of some kind. A
degree of GDB gymnastics are required if you have a multistage bootstrap
such as I described, since the debugger treats each one as separate
binaries.
