Forum: ARM programming with GCC/GNU tools LPC2103 - UART0 Interrupt Problem
Author: Jongmun Kim (Company: inno) (jmkim519)
Dear all,
I am Using LPC2103, I had Configured UART0 to IRQ
When working, VIC Register Status is
  vicIntSelect = 0;
  vicIntEnable = 0x000040;
  vicIRQStatus = 00000040;
  vicVectCtrl0 = 0x000026;
  vicVectAddr0 = 0x000380;
  vicVectAddr  = 0x000380;
But Didn't happen to uart0_rx_isr Routine
Could some body help me regarding this.
          /* Exception Vector Table */
_vectors:       ldr     PC, Reset_Addr
                ldr     PC, Undef_Addr
                ldr     PC, SWI_Addr
                ldr     PC, PAbt_Addr
                ldr     PC, DAbt_Addr
                nop
                ldr     PC, [PC,#-0xFF0]
                ldr     PC, FIQ_Addr
           /* My Working Code */
#include "LPC210x.h"
void uart0_rx_isr(void);
int main()
        PINSEL0 &= (~(0xF) & 0xFFFFFFFF);
        PINSEL0 |= 0x5;
        UART0_FCR = 0x7;
        UART0_LCR = 0x83;
        UART0_DLL = 0x41;
        UART0_DLM = 0x0;
        UART0_LCR = 0x3;
        /* Setting Interrupt */
        UART0_IER = 0x3;
        VICIntEnClr     = 0xFFFFFFF0;
        VICIntSelect    = 0x00000000;
        VICVectCntl0    = ((0x1<<5) | 6);
        VICVectAddr0    = (unsigned long)uart0_rx_isr;
        VICIntEnable    = (1<<6);
        volatile unsigned long uart0IIR = 0;
        uart0IIR = UART0_IIR;
        while (!(UART0_LSR & 1<<5));
        UART0_THR = 'T';
        VICVectAddr = 0;
Author: A. K. (prx)
Is the processor interrupt enabled? ARM7 startup codes often call main()
with interrupts disabled and your main enables the interrupts in VIC but
not in the processor. Also it is rather undefined what happens once
main() terminates.
BTW: A local variable of an interrupt handler almost never has to be
"volatile". Only vars which could be accessed outside of the compilers
visibility have to be volatile (such as a main program's var accessed by
an interrupt handler).
Thx. For your help.
But I am a beginner, I don't know exactly.
Here My startup code, For processor interrupt Enable, what I have to do?
/* Stack Sizes */
.set  UND_STACK_SIZE, 0x00000004    /* stack for "undefined instruction" interrupts is 4 bytes  */
.set  ABT_STACK_SIZE, 0x00000004    /* stack for "abort" interrupts is 4 bytes                  */
.set  FIQ_STACK_SIZE, 0x00000004    /* stack for "FIQ" interrupts  is 4 bytes               */
.set  IRQ_STACK_SIZE, 0X00000004    /* stack for "IRQ" normal interrupts is 4 bytes          */
.set  SVC_STACK_SIZE, 0x00000004    /* stack for "SVC" supervisor mode is 4 bytes          */
/* Standard definitions of Mode bits and Interrupt (I & F) flags in PSRs (program status registers) */
.set  MODE_USR, 0x10                /* Normal User Mode                     */
.set  MODE_FIQ, 0x11                /* FIQ Processing Fast Interrupts Mode             */
.set  MODE_IRQ, 0x12                /* IRQ Processing Standard Interrupts Mode           */
.set  MODE_SVC, 0x13                /* Supervisor Processing Software Interrupts Mode       */
.set  MODE_ABT, 0x17                /* Abort Processing memory Faults Mode             */
.set  MODE_UND, 0x1B                /* Undefined Processing Undefined Instructions Mode     */
.set  MODE_SYS, 0x1F                /* System Running Priviledged Operating System Tasks  Mode  */
.set  I_BIT, 0x80                   /* when I bit is set, IRQ is disabled (program status registers) */
.set  F_BIT, 0x40                   /* when F bit is set, FIQ is disabled (program status registers) */
.text
.arm
.global  Reset_Handler
.global _startup
.func   _startup
_startup:
# Exception Vectors
                ldr     PC, Undef_Addr
                ldr     PC, SWI_Addr
                ldr     PC, PAbt_Addr
                ldr     PC, DAbt_Addr
                nop              /* Reserved Vector (holds Philips ISP checksum) */
                ldr     PC, [PC,#-0xFF0]  /* see page 71 of "Insiders Guide to the Philips ARM7-Based Microcontrollers" by Trevor Martin  */
                ldr     PC, FIQ_Addr
Reset_Addr:     .word   Reset_Handler    /* defined in this module below  */
Undef_Addr:     .word   UNDEF_Routine    /* defined in main.c  */
SWI_Addr:       .word   SWI_Routine      /* defined in main.c  */
PAbt_Addr:      .word   UNDEF_Routine    /* defined in main.c  */
DAbt_Addr:      .word   UNDEF_Routine    /* defined in main.c  */
IRQ_Addr:       .word   IRQ_Routine      /* defined in main.c  */
FIQ_Addr:       .word   FIQ_Routine      /* defined in main.c  */
                .word   0          /* rounds the vectors and ISR addresses to 64 bytes total  */
# Reset Handler
Reset_Handler:
        /* Setup a stack for each mode - note that this only sets up a usable stack
        for User mode.   Also each mode is setup with interrupts initially disabled. */
          ldr   r0, =_stack_end
          msr   CPSR_c, #MODE_UND|I_BIT|F_BIT   /* Undefined Instruction Mode  */
          mov   sp, r0
          sub   r0, r0, #UND_STACK_SIZE
          msr   CPSR_c, #MODE_ABT|I_BIT|F_BIT   /* Abort Mode */
          mov   sp, r0
          sub   r0, r0, #ABT_STACK_SIZE
          msr   CPSR_c, #MODE_FIQ|I_BIT|F_BIT   /* FIQ Mode */
          mov   sp, r0
           sub   r0, r0, #FIQ_STACK_SIZE
          msr   CPSR_c, #MODE_IRQ|I_BIT|F_BIT   /* IRQ Mode */
          mov   sp, r0
          sub   r0, r0, #IRQ_STACK_SIZE
          msr   CPSR_c, #MODE_SVC|I_BIT|F_BIT   /* Supervisor Mode */
          mov   sp, r0
          sub   r0, r0, #SVC_STACK_SIZE
          msr   CPSR_c, #MODE_SYS|I_BIT|F_BIT   /* User Mode */
          mov   sp, r0
        /* copy .data section (Copy from ROM to RAM) */
                ldr     R1, =_etext
                ldr     R2, =_data
                ldr     R3, =_edata
1:            cmp     R2, R3
                ldrlo   R0, [R1], #4
                strlo   R0, [R2], #4
                blo     1b
        /* Clear .bss section (Zero init)  */
                mov     R0, #0
                ldr     R1, =_bss_start
                ldr     R2, =_bss_end
2:        cmp     R1, R2
                strlo   R0, [R1], #4
                blo     2b
        /* Enter the C code  */
                b       main
.endfunc
.end
I figure out the problem.
When I change processor Interrupt Enable, it working.
I change Below
first, Stack size change
  .set  IRQ_STACK_SIZE, 0X00000080
second, IRQ Enable
  msr   CPSR_c, #MODE_USR   /* User Mode */
