Attached files:Hey, I am a novice in the microcontroller and i have since one Week a Problem. I engraved this code below on mysmatcontrolM8 (s. picture). But, i obtain only weird character although it is working property on STK500 with atmega8. I have already verified the frequenz, the Baud Rate and all are OK. However, i obtain only weird character I viewed the mysmartcontrolM8 product description: power supply via USB connection, 5 V or 3.3 V. I think, that maybe the failing is the diference between the power supply of my PC and mysmatcontrolM8 (atmega8) !!! is that right!?! And please which transformer can i use? Or, where is my fault!?! can somebody help me!!! thank you
#ifndef F_CPU /* In the new version of the WinAVR/Mfile Makefile guideline One can defined F_CPU in the Makefile, a repeated definition here would lead to a compiler warning . therefore "prevention" through #ifndef/#endif This "Prevention" can lead to Debugger, if AVRStudio use a another, not the hardware fitting Clock rate: Then the following definition doesn't use, but instead the default value (1 MHz?) of AVRStudio - hence the Output of a warning if F_CPU yet does not define:*/ #warning "F_CPU was not defined yet, now make up with 3686400" #define F_CPU 3686400L // Systemtakt in Hz - define as long>> Without errors in the computation #endif #define BAUD 9600L #define UBRR_VAL ((F_CPU+BAUD * 8)/(BAUD*16)-1) //clever round #define BAUD_REAL (F_CPU/(16*(UBRR_VAL+1))) //real baud rate #define BAUD_ERROR ((BAUD_REAL*1000)/BAUD-1000) //Error per thousand #if ((BAUD_ERROR>10)||(BAUD_ERROR<-10)) #error Systematic error in the baud rate more than 1% and thus too high! #endif #include <avr/io.h> #include <stdlib.h> #include <inttypes.h> #include <util/delay.h> void USART_Init(void) { UBRRH = (unsigned char)(UBRR_VAL>>8); // Set baud rate UBRRL = (unsigned char)UBRR_VAL; UCSRB |= (1<<RXEN)|(1<<TXEN); // Enable receiver and transmitter UCSRC = (1<<URSEL) | (1<<UCSZ0)|(1<<UCSZ1); // Set frame format: 8data, 1stop bit }//end USART_Init() void USART_Putc(unsigned char c) { while (!(UCSRA & (1<<UDRE))); // Do nothing until data have been transmited UDR = c; // Put data into Buffer, sends the data _delay_ms(10); }//end USART_Putc() void USART_Puts (char *string) { while( *string != '\0' ) //as long as *string != '\0' so unlike the "stringer end-character" { USART_Putc(*string); string++; } }//end USART_Puts() int main(void) { USART_Init(); USART_Puts("\r\n"); while(1) { USART_Puts("Hey !!!!"); } return 0; } //end main() |
How did you connect the board to your PC? I wonder about the physical connection. The reason why I'm asking is: I miss to see some kind of level converter on the board (which doesn't necessarily mean it's not there).
Hey, thank you for your interrest. I have connected on PC over the USB interface, which provides a virtual COM3-Port to the PC. greet
I see. I assume you've made sure the baudrate is correct at 9600? If so, I'm running out of ideas.
Is your clock really 3.68 MHz? By default the ATmega8 is running on the internal 1 MHz RC oscillator. Make sure you have set all the necessary fusebits for running with the external crystal (see datasheet).
hey, i have it. all is ok. except that during all this time, I compiled the bad .exe file. stupid! thank all
