Forum: ARM programming with GCC/GNU tools Linking order and startup files
Author: Oliver B. (irq)
I'm comparing linker scripts for an ARM chip and wonder how to integrate
startup code properly. It is generated from an assembler file which is
transformed into object code like the other c-files.
After compiling the linker is called in the Makefile:
$(CC) $(THUMB) $(CFLAGS) $(ALLOBJ) --output $@ $(LDFLAGS)
The used variables should be self-explaining, $(AllOBJ) referres to all
object files meaning that of the previous assembler and c-files, which
are placed in the same directory.
Now I'm asking myself, what the output (ELF) does look like - is the
startup code really executed first and especially WHY ?
Maybe I could get it working by trial and error but I would really be
interested how it actually works. Can you tell me or do you know
ressources regarding this issue?
THANKS!
Further information: I'm comparing two ld-scripts, the first one seems
to ignore startup related stuff and the second one includes it manually:
First:
.text :
        . = ALIGN(0x80); /* PM0056, Rev.1 (4/2009), 4.3.3 */
        _isr_vectorsflash_offs = . - 0x08000000;
        KEEP(*(.isr_vectorsflash))
        . = ALIGN(4);
        *(.text)                   /* code */
        *(.text.*)                 /* remaining code (-ffunction-sections)*/
        *(.stub .gnu.linkonce.t.*)
        *(.rodata .rodata.* .gnu.linkonce.r.*) /* read-only data (constants) */
        *(.glue_7 .glue_7t)        /* redundant for thumb2 ?! */
        . = ALIGN(4);
        _etext = .;
        /* This is used by the startup in order to initialize the .data secion */
        _sidata = _etext;
    } >FLASH
Second:
.text :
      KEEP(*(vector vector.*))
      __startup_code__ = .;
            $(TargetDir)startup.o (.text)         /* Startup code */
      __startup_code_end__ = .;
      *(.text .text.*)
      *(.gnu.linkonce.t.*)
      *(.glue_7)
      *(.glue_7t)
      *(.gcc_except_table)
      . = ALIGN(4);
      *(.rodata .rodata*)
      *(.gnu.linkonce.r.*)
      . = ALIGN(4);
      _etext = .;
   } > FLASH
The GNU tools offer some tools to "look" into the elf-file. I'm usually
just using the disassembly to verify things. It can be generated with
objdump (make calls objdump to generated it as *.lss when using my
"WinARM makefile template).
> - is the startup code really executed first
First of all the Controller looks for the reset-address and "jumps"
(sets PC) to this address. Since you are using a Cortex-M3 the
reset-address is expected at Address 0x00000004 (after the initial stack
pointer address at 0x00000000). It's not important where the
startup-code is located as long as it starts at the address given at
0x04.
Because it's address of the startup is given.
"The prove of the pudding is the eating." (Samba Documentation)
gcc Manual, binutils/ld Manual, Cortex M3 Technical
Reference/Programming Guide
Why do you think "startup related stuff" is ignored?
> First:
> .text :
>         . = ALIGN(4);
>         *(.text)                   /* code */
> (constants) */
>         . = ALIGN(4);
>         _etext = .;
> secion */
>         _sidata = _etext;
>     } >FLASH
I know this script from somewhere...
As you can see the all important input section with the reset-vector
(.isr_vectorsflash) is located first in the FLASH output-section. Since
the exceptions table is the only element in the input-section and the
reset-handler's address is the 2nd Element in the table the controller
finds the pointer to the startup-code. In this case the startup-code is
just treated as any other code (.text) since it's not important where it
is located.
> Second:
> .text :
>       *(.text .text.*)
>       *(.glue_7)
>       *(.glue_7t)
>       . = ALIGN(4);
>       *(.rodata .rodata*)
>       . = ALIGN(4);
>       _etext = .;
>    } > FLASH
Here the input-section with the vector-table is named vector instead of
.isr_vectorsflash in the previous example but the concept is the same:
The Reset-Hander Address in the vector still hast to point the the
startup machine-code. The only "real" difference I see is, that the
.text input-section in the object file startup.o are explicitly placed
right after the vector-table in memory (see binutils/ld manual). The
remaining code in the .text input-section(s) follows. I can't tell why
this approach has been chosen without looking into the reset of the
code.
Thank you for your explanations. It took me some time but now the basic
principles of linking are a bit clearer to me.
I wrote my own very little linker script that works fine now, but I
needed a little tweak:
The startup code I use is startup_stm32f10x_md.s, taken 100% from the
STM Standard Peripherial Lib. As I said, it works fine, but I had to
edit the isr_vector section:
.section  .isr_vector,"a",%progbits
.type  g_pfnVectors, %object
.size  g_pfnVectors, .-g_pfnVectors
g_pfnVectors:
  .word  _estack
  .word  (Reset_Handler+1)  <- PLUS 1 HERE
The disassembly showed me an address, that pointed directly to
Reset_Handler, that didn't work. I rememberred this site:
http://209.85.135.132/search?q=cache:Sn58U6UOeBUJ:...
Which says, the initial PC must be the address + 1. I tried baking a
cake without a recipe - and it tasted yummi... Knowing WHY this time,
but not how to fix it properly. I do not guess STM has a bug in its
code.
Here is my linker script:
MEMORY
  RAM      (RWX) : ORIGIN = 0x20000000, LENGTH = 20K
  FLASH    (RX)  : ORIGIN = 0x08000000, LENGTH = 128K
_estack = ORIGIN(RAM)+LENGTH(RAM);
SECTIONS
  .text :
    KEEP(*(.isr_vector))
    *(.text)
    *(.text.*)
    _sidata = .;
  } >FLASH
  .data  : AT ( _sidata )
    _sdata = . ;
    *(.data)
    _edata = . ;
  } >RAM
  .bss (NOLOAD):
    _sbss = .;
    *(.bss .bss.*)
    *(COMMON)
    . = ALIGN(4);
     _ebss = . ;
  } >RAM
> g_pfnVectors:
>   .word  _estack
Even if it works the guide on this page is really minimal. Too minimal
in my opinion.
- When using C the startup should at least copy data and zero-init.bss.
Not needed in the code on the page since there is nothing in bss and
data but as it is now it's not a good starting-point.
- It has been written >1e8 times: don't call ld directly use the
frontend for linking too.
Is expect the main reason for the problem are missing options to the
linker, maybe the linker does not "know" that it has to use thumb-style
addressing and uses ARM-mode addressing instead. Since the options used
for compiling/linking are not given: have -mcpu=cortex-m3 and -mthumb
been passed as options for linking too?
Hm, I played around with my compiler/linker options (copy'n paste from
other Makefiles), but had no success. Yes, the m-options are supplied -
at least to gcc. Is the "+1" thumb specific?
Here is my Makefile:
AFLAGS = -mcpu=cortex-m3 -mthumb -Wa,-gdwarf-2
CFLAGS = -mcpu=cortex-m3 -mthumb -O0 -gdwarf-2
LFLAGS = -T simple.ld -Wl,--gc-sections
all:
  arm-elf-gcc -c $(AFLAGS) startup_stm32f10x_md.s
  arm-elf-gcc -c $(CFLAGS) main.c
  arm-elf-gcc    $(CFLAGS) startup_stm32f10x_md.o main.o $(LFLAGS)
