linker error undefined ref to `_sbrk'
OP (Company: Shalaka Tech. Pvt. Ltd.) #1436641
• ▲ useful
▼ not useful
Hello All,
I am using LM3S811 evaluation kit and code red development tools for
firmware development.
Whenever i call functions atoi or atof from stdlib, linker gives
following error.
: In function `_sbrk_r':
sbrkr.c:(.text+0x12): undefined reference to `_sbrk'
make: *** [SHT11_Rev5oct.axf] Error 1
For this problem,I have referred link  http://embdev.net/topic/129753 on
this forum.
As per the instructions i have edited linker script in 'standalone.o'
. Also created syscalls.c and added to my project. But its unable to
link; giving error 'undefined reference to `_sbrk''
My project folder is attached for ref.
What could be reason? Kindly help me.
Thanks in advance :-)
Ameya
Moderator #1437471
• ▲ useful
▼ not useful
Because there is no function named _sbrk in it.  You call it sbrk.
Guest #1446455
• ▲ useful
▼ not useful
Ameya Hardikar,
did you find the solution ?
I 've got similar probleme with my compilation :
// output of "make" :
  LD    gcc/uart_check.axf
/opt/CodeSourcery/arm-2009q1/bin/../lib/gcc/arm-none-eabi/4.3.3/../../..
/../arm-none-eabi/lib/thumb2/libc.a(lib_a-sbrkr.o):  In function
`_sbrk_r':
make: *** [gcc/uart_check.axf] Error 1
/* end of quotation */
It looks similar, true ? Any suggestion ?
Jörg Wunsch, the "_sbrk" is in a library, and it is not normal that this
error occur, I do not understand...
Gilles Bulthé
Guest #1446500
• ▲ useful
▼ not useful
In fact,
I have this code :
==========quotation :
typedef struct historyList{
    char* CmdLine;
    int CmdSize;
    struct historyList* prev;
    struct historyList* next;
} history;
history*
UARTHistoNew()
    history* New=(history*)malloc( sizeof(history));
    New->CmdLine = "";
    New->CmdSize = 0;
    New->prev=NULL;
    New->next=NULL;
    return New;
[in my main function :]
    static history *pHistoList=NULL;
    // init the histo (Normalement, ONLY ONE TIME !) :
    if (pHistoList==NULL) pHistoList = UARTHistoNew();
=========end of quote
And the compilation pb disappears when I disable the last line ("if
(pHistoList==NULL) pHistoList = UARTHistoNew()").
Can anyone help me ?
Thanks in advance.
Gilles.
Guest #1446534
• ▲ useful
▼ not useful
Tilo,
thank you so much.
I learn by your link and
http://tech.dir.groups.yahoo.com/group/lpc2000/message/22018?var=1 that
malloc needs dynamics library witch needs _sbrk_r, etc.
So, I will use another way, with no malloc.
Ex :
===quote :
history*
UARTHistoNew()
//    history* New = (history*)malloc( sizeof(history));
    history New;
    New.CmdLine = "";
    New.CmdSize = 0;
    New.prev=NULL;
    New.next=NULL;
    return &New;
[etc]
===========end
Correct ? I think this way will allow me to avoid using malloc and
dynamic livraries...
Thanks,
Gilles.
OP (Company: Shalaka Tech. Pvt. Ltd.) #1446547
• ▲ useful
▼ not useful
Hello Gilles,
Yeah i got the problem solved. But at a cost of loosing much of my code
memory space. You can change c library which your project is referring.
Currently you may be using newlib(none). Change this to newlib(nohost)
and  build your code. But then newly generated .axf will be of almost
double size than previous one. Solution is to define_sbrk in your
project and build it.
Keil IDE provides syscall.c file with the definition of _sbrk. refer it.
also check this:
http://support.code-red-tech.com/CodeRedWiki/CLibrary
Thank you,
Ameya
Guest #1446679
• ▲ useful
▼ not useful
Thank you to all of you.
The way to change the dynamic library in order to have it for my
embedded application may be too hard. So I'll give up here, after
regarding this "high-level" solution.
Ameya, your solution may be THE one, but for my little application, I
will prefer working in static than in dynamic. More stable. And I have
small memory space.
Stefan, thank for your note ! For sure, I spoke to fast...
(unforgivable!)
Best regards,
Gilles.
(Company: student) #1447600
• ▲ useful
▼ not useful
Sorry if this is not related to your topic, in another thread and saw
this topic was related, i just "cross-read" this thread. ;-)
But maybe this might help you "http://embdev.net/topic/129607";. I got
the same issue and solved it in just implementing a stub function for
_sbrk. I dont use dynamic memory allocation in my sourcecode, but the
linker wants a regerence to _sbrk... if you dont use malloc (or equal
functions) you should be safe with a stub.
