Forum: ARM programming with GCC/GNU tools cygwin replaces YAGARTO under Eclipse
Author: Greg S. (Guest)
I have a development station (WinXP Pro SP3) that is setup to use the
YAGARTO tool chain under Eclipse (following the directions on the
www.yagarto.de website).
I recently installed cygwin on the same machine, but now I am unable
create new projects that use the YAGARTO tool chain. One of the projects
I created before installing cygwin, still works and compiles using
YAGARTO (the selected toolchain is, "No ToolChain"). But all of the
projects I have created since can not access YAGARTO. There is no
YAGARTO option listed under 'New->C Project-> Toolchains' or under
'Project->Properties->C/C++ Build->Tool> Chain Editor' (Cygwin, Linux,
MacOS, WinGW, and Solaris GCC all show-up however). Before I installed
cygwin, 'No ToolChain' showed up in both the 'New->C Project->
Toolchains' and 'Project->Properties->C/C++ Build->Tool Chain Editor'
drop downs (fyi in the old project, if I uncheck "Display compatible
toolchains only" then all of the above mentioned tool chains show-up
including "No ToolChain").
I checked my Windows PATH and cygwin is not even listed. It was listed
first in the PATH variable inside Eclipse. I reversed the order putting
yagarto first, but the behavior remains the same.
I would like to keep cygwin installed on this computer, but need YAGARTO
working again right away so that I can continue building and debugging
an AT91SAM9263 project. Does anyone know how I can select the YAGARTO
toolchain when I create new projects.
greg
Author: Oliver B. (irq)
You can specify the paths to gcc, gdb... manually.
E.g. go to Run -> Run Configurations. Create a new one for C/C++ and
select "gdb" in the tab "Debugger". There you can specify the executable
for gdb. I didn't find it for gcc but I'm quite sure there is, maybe in
build configurations (have no project at hand, so everythink is greyed
out for me).
