Forum: ARM programming with GCC/GNU tools olimex AT91sams256 + ARM-USB-TINY Unable to debug from RAM
Author: Rohit Chandel (rohit123)
I am using Olimex ARM-USB-TINY for debugging. I installed the yogarto
toolchain with the help of the .exe supplied with the ARM-USB-TINY cd. I
am able to run the flash version of the example project given for my
board with AT91sam7s256. But there is no project to run from RAM. So I
followed James P. Lynch's tutorial and downloaded the example projects
for olimex AT91sams64 and modified as mentioned by the author for
sam256. Although the project builds with few quirks but I am unable to
debug it.
Modifications to build-
- I use sam7flash.script instead of script.ocd as supplied with tutorial
since I got a build error which asked for this file. I do not know how
to specify script.ocd instead of sam7flash.script.
- I Added armusbocd_tiny.cfg and armusbocd.cfg which must be present in
the project directory for the toolcain to work
Following Peter's tutorial I created debug launch configuration for
debugging from RAM as:
Initialize command:
target remote localhost:3333
Run command:
monitor soft_reset_halt
monitor armv4_5 core_state arm
monitor mww 0xffffff60 0x00320100
monitor mww 0xfffffd44 0xa0008000
monitor mww 0xfffffc20 0xa0000601
monitor wait 100
monitor mww 0xfffffc2c 0x00480a0e
monitor wait 200
monitor mww 0xfffffc30 0x7
monitor wait 100
monitor mww 0xfffffd08 0xa5000401
set remote memory-write-packet-size 1024
set remote memory-write-packet-size fixed
set remote memory-read-packet-size 1024
set remote memory-read-packet-size fixed
monitor mww 0xfffffd00 0xa5000004
monitor mww 0xffffff00 0x01
monitor reg pc 0x00000000
monitor arm7_9 sw_bkpts enable
load
continue
Now when I launch debug configuration it gives following output in
console:
0x0000080c in ?? ()
Warning: /cygdrive/C/gccfd/projects/demo_at91sam7_p64_blink_ram: No such file or directory.
requesting target halt and executing a soft reset
core state: ARM
memory write caused data abort (address: 0xffffff60, size: 0x4, count: 0x1)
monitor wait 100
monitor wait 200
monitor wait 100
pc (/32): 0x00000000
software breakpoints enabled
load
Loading section .text, size 0xf48 lma 0x200000
Loading section .data, size 0x44c lma 0x200f48
Start address 0x200000, load size 5012
Transfer rate: 10 KB/sec, 835 bytes/write.
continue
It hangs after that and shows "launching<projectname> 27% progress
Can anybody suggest me how to make it work.
Regards
Rohit
Author: Michael Fischer (mifi)
Hello Rohit,
it looks that you use a compiler which is based on Cygwin,
is this possible?
The YAGARTO toolchain do not need Cygwin. You can find a SAM7S256
example on the YAGARTO page too which comes with a example to
debug in RAM.
Do you have YAGARTO or GCCFD?
Best regards,
Michael
Hi Michael,
First of all thanks for replying to the post.
is this possible?
I really do not have idea. I had no success with installing the
toolchain given in Peter Lynch's tutorial because of various reasons -
1. on page-19 of the tutorial open on chip debugger has changed on
yagarto website because of some licensing issues. I do not have much
idea as to how to use the changed one.
2. All the versions of the other Yagarto downloads have also changed.
3. There is no mention for setup for of ARM-USB-TINY in the tutorial,
but that one is meant for hobbyists.
The exe which came along the olimex jtag has installed in following
directory structure:
C:\gccfd\|
         |-ARM-USB-OCD-DRIVER
         |-codesourcery-arm-2008q1
         |-eclipse
         |-openocd
         |-utils
         |-yagarto
since yagarto is listed there I think its yagarto toolchain.
openocd directory also differs from your tutorial.
I would love to do follow the tutorial since it does not add any extra
complexity to the environment in the form of extra lines in make file,
in different linker scripts etc. in order to support more than one
target.
Please guide me how to build the toolchain explained in Peter Lynch's
tutorial with current changes of Yogarto most importantly for
ARM-USB-TINY.
Please ask me if you need any more info to understand the problem.
Thanks and Regards
Rohit
Hello Rohit,
it looks that you have two compilers:
1. CodeSourcery
2. YAGARTO
A new CodeSourcery Lite compiler can be found here:
http://www.codesourcery.com/sgpp/lite/arm
And the YAGARTO version can be found here:
http://www.yagarto.de/
First of all you should decide which compiler you want to use.
Regards,
Michael
Hi Michael,
Ok, if I can follow the Peter's tutorial by having YAGARTO compiler than
I"ll go for it. I"ll uninstall everything and follow tutorial from
start.
But could you please answer my other doubts:
Regards
Rohit
