Yagarto tools - Make 64 bit windows - Error
Since make is independent of the code generation tools, you might simply
replace it with a 64 bit version of make. There is one available here:
http://www.equation.com/servlet/equation.cmd?fa=make
An alternative but somewhat heavyweight solution may be to run a 32bit
version of Windows in a virtual machine on your 64bit platform.
Both VMware Server and Virtual PC are free and will allow you to do
this. One advantage of a VM is that it provides a consistent and
standardised virtual platform regardless of the physical hardware and
drivers installed. Because you can have a virtual network between the VM
and the host (and the rest of your physical network) accessing files in
either environment can be seamless.
http://www.microsoft.com/downloads/details.aspx?FamilyID=28C97D22-6EB8-4A09-A7F7-F6C7A1F000B5&displaylang=en
http://www.vmware.com/products/server/
If you do not have a spare Windows license to install on the VM, you can
use one of the IE compatibility test VHDs for Virtual PC, which are in
fact time-limited full OS installations.
http://www.microsoft.com/downloads/details.aspx?displaylang=en&FamilyID=21eabb90-958f-4b64-b5f1-73d0a413c8ef
Clifford
Guest
I got the same error message, but the solution was plain simple:
Don't install the yagarto into a directory containing spaces (like
"Program Files(x86)")
On my Win7 64bit machine, installing the toolkit in c:\yagarto\ fixed
the issues...
Oh yes; never do that with any GNU tools, especially make.  You may be a
bit late with the suggestion however; thread necromancy is seldom
useful.
Guest
Thank you very much!
I have searched longer days.
Now I read this post and my problem is solved!
Thanks.
Helge
Guest
Alternatively, edit the PATH environment variable to use the *short
names* for the directories where Yagarto is intalled, e.g.:
PATH=C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\yagarto-tools-20100703\bin;C:\Program Files (x86)\yagarto\bin
becomes:
PATH=C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\PROGRA~2\YAGART~1\bin;C:\PROGRA~2\yagarto\bin
(Use 'dir /x' in the command shell to check the actual short name of
each directory, and see
http://geekswithblogs.net/renso/archive/2009/10/21/how-to-set-the-windows-path-in-windows-7.aspx
for info on editing the PATH)
-Owen
A question of your own? This thread is over 17 years old. Ask it in a thread of its own – more people read along there, and it gets answered more often and sooner.
Start a new thread
