Forum: µC & Digital Electronics Atmega168 - Sleep mode
Author: Jochen Spieker (Guest)
i have got some problems with my arduino that is equipped with an atmega
168.
I want to put the atmega into sleep mode for x milliseconds. The wakeup
is realized with a Timer2 interrupt. If I use in the loop function the
"delay(1)" just for testing purposes the led that is connected to pin 13
blinks in 5 sec interval. (as it should be)
But if I remove the delay and write the "sleep_now()" instead, the led
flashes every 10 seconds. Does anybody have an explanation for this
weird behavior?
Cheers,
Jochen
Here is the code:
#include <avr/interrupt.h>
#include <avr/io.h>
#include <avr/sleep.h>
int volatile time=5000; //sleep time
boolean volatile timerEnabled=false;
int volatile  counter = 0;
void sleepNow()         /
    set_sleep_mode(SLEEP_MODE_PWR_SAVE);   // sleep mode is set here
    sleep_enable();          // enables the sleep bit in the mcucr
register
                             // so sleep is possible. just a safety pin
    sleep_mode();            // here the device is actually put to
sleep!!
                             // THE PROGRAM CONTINUES FROM HERE AFTER
WAKING UP
    sleep_disable();         // first thing after waking from sleep:
                             // disable sleep...
void setup() {
 // Serial.begin(19200);
  pinMode(13,OUTPUT);
  TCCR2A |= (1 << WGM21); //ctc mode
  OCR2A = 124; //set timer maximum to 124
  TCNT2 = 0;//reset timer
  TCCR2B = 0b00000100; //((1 << CS22)|(1 << CS20));  //prescaler 64
  sei();
ISR(TIMER2_COMPA_vect) {
  counter ++;
  if (counter == time) {
     TCCR2A =0; // stop timer compA interrupts
     counter=0;
     timerEnabled=false;
void loop() {
 if(timerEnabled==true)
 sleepNow();
 //delay(1100);
  else {
      //Serial.println("TEST");
          timerEnabled=true;
          digitalWrite(13,HIGH);
          delay(10);
          digitalWrite(13,LOW);
          //time=1000;
          TCNT2 = 0;              //reset timer
          TIMSK2 |= (1 << OCIE2A);  //enable timer interrupt
Author: atmegadennis (Guest)
Hi Jochen,
perhaps, it is the missing bracket here
void sleepNow()
so this part of the programm will not work
Author: Stefan_KM (Guest)
Right, the bracket is missing.
Hi guys,
thanks for the reply, but the bracket is definitly not the cause. I have
deleted it by mistake when i was edinting the code to post it here in
the forum.
The code compiles without problems.
Cheers
Jochen
Author: Tom (Guest)
1) Deactivated ALL OTHER interrupts?? Maybe some pin is catching
interference?
2) Watchdog disabled?
Maybe it is the startup time the atmega168 needs to wakeup. Does anybody
know how much it is?
webmaster@embdev.netContactAdvertising on EmbDev.net
