Forum: ARM programming with GCC/GNU tools Linker error with LPC2378 - example code
Author: Phani Kumar (phani)
I am trying to use the WinARM (WinARM-20070505) for LPC2378.
I took the example "C:\WinARM\examples\lpc2378_demo1" and try to add a
dummy code to just blink LED's. But, I am getting some linker errors.
So to single out the problem, I have only main.c and startup.S and
removed all other files from the makefile. Even in the main.c I have
removed all the other code and just have a while(1) loop to blink the
LED's. With this again the same error happens (as mentioned below).
Any suggestions are welcome.
-------- begin (mode: ROM_RUN) --------
arm-elf-gcc (GCC) 4.1.2 (WinARM 4/2007)
Copyright (C) 2006 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is
NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR
PURPOSE.
Assembling (ARM-only): Startup.S
arm-elf-gcc -c -mcpu=arm7tdmi-s  -I. -x assembler-with-cpp -DROM_RUN
-D__WinARM__ -D__WINARMSUBMDL_LPC2378__
-Wa,-adhlns=Startup.lst,-gdwarf-2 Startup.S -o Startup.o
Compiling C: main.c
arm-elf-gcc -c  -mcpu=arm7tdmi-s  -I. -gdwarf-2 -DROM_RUN -D__WinARM__
-D__WINARMSUBMDL_LPC2378__  -Os -Wall -Wcast-align -Wimplicit
-Wpointer-arith -Wswitch -ffunction-sections -fdata-sections
-Wredundant-decls -Wreturn-type -Wshadow -Wunused -Wa,-adhlns=main.lst
-ICommon/inc -Wcast-qual -MD -MP -MF .dep/main.o.d -Wnested-externs
-std=gnu99 -Wmissing-prototypes  -Wstrict-prototypes
-Wmissing-declarations main.c -o main.o
Linking: main.elf
arm-elf-gcc  -mcpu=arm7tdmi-s  -I. -gdwarf-2 -DROM_RUN -D__WinARM__
-Wa,-adhlns=Startup.lst  -ICommon/inc -Wcast-qual -MD -MP -MF
.dep/main.elf.d Startup.o   main.o     --output main.elf -nostartfiles
-Wl,-Map=main.map,--cref,--gc-sections -lc  -lm -lc -lgcc
-T.//LPC2378-ROM.ld
c:/winarm/bin/../lib/gcc/arm-elf/4.1.2/../../../../arm-elf/bin/ld.exe:
address 0x700 of main.elf section .stack is not within region RAM
make.exe: *** [main.elf] Error 1
> Process Exit Code: 2
> Time Taken: 00:01
With best regards,
Phani.
Author: Francis Kong (dinosaurkfb)
There should be something wrong with your link script. Attach your code
and link script, then people can help you
Author: Phani (Guest)
The linker script is attached. Also the main.c, main() is as follows.
Still not clear what may be missing.
   "Epsilon"
   LPC2378 Demo by Martin Thomas, Kaiserslautern, Germany
   http://www.siwawi.arubi.uni-kl.de/avr_projects/arm_projects
   Target:   LPC2378
   Board:    Olimex LPC-2378-STK
   Compiler: GNU arm-elf or arm-eabi toolchain
             (tested with WinARM 6/06)
   Partly based on drivers from the NXP LPC23xx & 24xx
   example-collection available from www.nxp.com.
#define VERSION_STRING "0.3 beta^2 mthomas, KL, .de"
#include "LPC23xx.h"
#include "type.h"
#include "irq.h"
#include "target.h"
#include "timer.h"
#include "fio.h"
#include "uart.h"
// LED1 (MCIPWR on Olimex LPC-2378-STK has an indicator LED)
#define LED1_FIOPIN  FIO0PIN
#define LED1_FIOSET  FIO0SET
#define LED1_FIOCLR  FIO0CLR
#define LED1_MASK    (1UL<<21)
#define INBUF_SIZE   0x80
#define UART_NUM     0
#define NEXTLINE     "\r\n"
#define ENTERKEY     '\r'
static const char welcome[] = NEXTLINE "Welcome to the WinARM LPC2378
Demo#1 \"Epsilon\"" NEXTLINE;
static const char version[] = "Version "VERSION_STRING NEXTLINE;
static void time_waste( unsigned int dv )
  volatile unsigned int cnt;
  for ( cnt=0; cnt<dv ; cnt++ ) { ; }
int main (void)
//Code added by Phani
  unsigned int u32counter = 0 ;
    FIO2DIR = 0x000000FF;    /* P2.0..7 defined as Outputs */
    FIO2CLR = 0x000000FF;    /* turn off all the LEDs */
  time_waste( 0x00090000 );
//#ifdef NOT_POSSIBLE_TO_COMPILE
  while(1)
      FIO2SET = 1 << u32counter;
      u32counter++;
      if ( u32counter > 8 )
          u32counter = 0;
//#endif
//Till here
  return 0;
Startup.S is also needed. i don't know how section .stack is assigned.
Startup file is attached.
With best regards,
Phani.
I found where the error comes from:
In your linker script, the lines below hide a mistake:
  . = ALIGN(4);
  _bss_end_ = . ;
  PROVIDE (__bss_end = .);
  .stack ALIGN(256) :
    *(.stack)
  *(.STACK)
    PROVIDE (_stack = .);
    . = ALIGN(4);
  } > RAM
I imagine that you want the .stack section to be 256 bytes aligned in
the RAM region, but the line ".stack ALIGN(256)" will set .stack to
address 0x700
, and obviously this address is not within RAM region
You should do like this:
  . = ALIGN(4);
  _bss_end_ = . ;
  . = ALIGN(256);
  .stack :
    *(.stack)
  *(.STACK)
    . = ALIGN(4);
  } > RAM
webmaster@embdev.netContactAdvertising on EmbDev.net
