Forum: ARM programming with GCC/GNU tools arm-elf-gcc linker quirk, no text, data, or bss sections
Author: Jeremy D. (jezz)
Posted on: 2009-05-24 02:10
I'm trying to get the arm-elf-gcc cross-compiler from GNUARM.org
(2008-10-19) to generate a binary for me, however I get an empty binary
file out of objdump. The best conclusion I can draw is that my linker
command isn't working right.
The compiler generates the listings right, so I can only assume the
objects are correct. Judging by the output of arm-elf-size, it looks
like objdump is doing its job alright as well. Through arm-elf-size, I
seem to be missing the data, text, and bss sections. These really ought
be there.
I've posted my linker script (taken and lightly modified from
at91sam7s_example_gamma) as well as what happens when I attempt to
compile the executable to http://pastebin.com/d6c63a237.
To clarify two things, I intend to target the AT91SAM7SE256, however
right now am just sticking to the AT91SAM7S512/AT91SAM7S-EK.
Can anyone help me out?
Thanks,
-Jeremy
Author: Martin Thomas (Guest)
Posted on: 2009-05-24 12:13
Try a rebuild without compiler-options -ffunction-sections /
-fdata-sections if this produces non-empty target sections you can just
continue without these options.
If you what to keep the unused code removal feauture, add an ENTRY
directive to the linker-script which "points" to the first instruction
in the reset-code (same instruction that is called on a reset-exception.
Posted on: 2009-05-24 19:52
The -ffunction-sections and -fdata-sections did the trick. It's good to
know about the unused code removal points as well.
Thanks,
-Jeremy
Note: the original post is older than 6 Months.
webmaster@embdev.netContactAdvertising on EmbDev.net
