Forum: µC & Digital Electronics Linux-Proof ARM Processor?
Author: Sd Fritze (sd-fritze)
Hello *,
I just want to start in ARM processors and it would be nice ift it has
following features:
  - Linux running
  - SD-Card interface
  - USB Host/Client
  - Ethernet (10Mbit or 100Mbit)
  - No BGA (TQFP or the thing where THT Sockets avialable)
  - Easy to get in Germany
  - Cheap :-)
  - Internal Flash(For U-Boot)
  - Decent Ram(would be nice if it is enough to run Debian for
StrongARM)
  - Interface for Audio Codecs (I²S?)
Bye,
SD-Fritze
Author: Robert Teufel (robertteufel)
Sd Fritze wrote:
> Hello *,
> following features:
>   - Linux running  No problem
>   - SD-Card interface  No problem
>   - USB Host/Client  No problem, it is called device though, not client
>   - Ethernet (10Mbit or 100Mbit)  No problem
>   - No BGA (TQFP or the thing where THT Sockets avialable) Big problem
>   - Easy to get in Germany don't know
>   - Cheap :-) depends on your definition of cheap
>   - Internal Flash(For U-Boot) huge problem
> StrongARM) --- DEFINE decent. Would definitely have to be on the board, not on
the chip
>   - Interface for Audio Codecs (I²S?)   No problem
> Bye,
> SD-Fritze
See my comments above.
You are looking for a higher end ARM9 / ARM11 StrongARM microprocessor
or similar with features that are only available in the microcontroller
area.
Your requirement of Linux would imply an ARM9 or upwards, these devices
have very high pincount and are manufactured in processes that might not
have flash implemented yet. High pincount --> usually BGA, new processes
--> usually no flash.
Flash for U-Boot can easily be external not a requirement to have it on
chip. There needs to be much more in the flash as well, e.g. the whole
OS, where else would it load from, external HDD!?
There is a significant chance you need to do some more homework in your
definition of the requirements.
Best, Robert
Author: Meino Cramer (mcc)
Hi SD-Fritze
look here
http://www.harerod.de/centipad/english/index.html
and check, whether it fits your needs.
Kind regards,
mcc
Author: Florian (Guest)
the available ARM SoC without a BGA case are quite limited. If its OK to
use a ready made module you have quite some options. Internal flash is
not that common for these as well, that's more the domain of 8 an 16 bit
controllers.
Atmel has a few that have internal flash and are available in a non-BGA
case.
Olimex should have evaluation board for these.
Apart from this you can look at the FriendlyARM modules
(http://www.friendlyarm.eu, Samsung ARM9 and with cheap baseboards.) and
some more industry modules by Karo (e.g. the TX27) or Garz & Fricke
(Adelaide).
Greetings
Florian
Author: Sebastian (Guest)
An AT91RM9200 will probably come close to what you need. The CentiPad is
one possible option. If you speak German, you might consider this one:
http://www.mme-berlin.de/arm9-modul/index.htm
I used it at work, and it's quite good. Though especially targeted
towards using Pascal for application development, you can use C/C++ as
well. Comes with pre-installed Linux (2.6 Kernel / BusyBox) on
MicroSD-Card and a ready-to-use toolchain (including IDE for Windows,
TFTP server and Terminal) on an USB stick. Documentation (German only,
though) is easy to understand, but still comprehensive. Support is
extraordinarily good, including assistance at customizing the system for
your application.
