Posted on: 2009-04-29 19:15
What defines where the call stack is located? I'm debugging in Eclipse and I see that the the bottom of the call stack is getting corrupted. (i.e the initiating call of the chain is ending up with an bad memory address.) But I can't find where these addresses are in memory. my boot.s and linker script define the ARM7 mode stack areas at the top of RAM. But when I look in there I do not see anything remotely near the return addresses that are displayed in Eclipse. All this on LPC2368 using yagato toolchain.
Posted on: 2009-04-30 21:10
Joe Dupre wrote: > What defines where the call stack is located? > I'm debugging in Eclipse and I see that the the bottom of the call stack > is getting corrupted. (i.e the initiating call of the chain is ending up > with an bad memory address.) But I can't find where these addresses are > in memory. > > my boot.s and linker script define the ARM7 mode stack areas at the top > of RAM. Show your boot.s and linker-script. > But when I look in there I do not see anything remotely near > the return addresses that are displayed in Eclipse. Please explain what you mean by "I do not see anything remotely near the return addresses that are displayed in Eclipse".
Posted on: 2009-04-30 22:03
Joe Dupre wrote: > What defines where the call stack is located? > > But I can't find where these addresses are > in memory. > There is no separate call stack; the return addresses, function arguments, and local variables share the same stack. Each function For that reason, the most common cause of call stack corruption is a buffer overrun or similar on a local variable or pointer argument to a caller's local variable. The call stack in the debugger filters the system stack to show just calls. The simplest way to find the error is to step your code observing the call stack until it corrupts - then you have located the offending line. If teh code is long you will need to to a divide an conquer approach and run the code repeatedly to narrow it down. Clifford
