Posted on: 2009-04-01 23:23
Attached files:Hi all, I try to make the freertos sam7x256 project sample working. I got it working right when I use the makefile, boot.S and atmel-rom.ld that came with freertos. Now I want to use the cstartup.S, new ld files and new makefile from the gamma_sample. I Have not been able to start the demo anymore. I want to use those new file because I would like to be able to have my vector in ram and use the garbage collector too. So now, I'm a little bit lost. I attached the files That I have modified to get the freertos demo working. is there somebody that can take a look at this ? or get something similar that he want to share ? Jonathan
Posted on: 2009-04-04 18:22
Jonathan Dumaresq wrote: > Hi all, > > I try to make the freertos sam7x256 project sample working. I got it > working right when I use the makefile, boot.S and atmel-rom.ld that came > with freertos. > > Now I want to use the cstartup.S, new ld files and new makefile from the > gamma_sample. > > I Have not been able to start the demo anymore. I want to use those new > file because I would like to be able to have my vector in ram and use > the garbage collector too. I have not done much with FreeRTOS but AFAIK it uses the SWI-Interrupt for context-switching. The gamma-example includes it's own swi-handler which does not know anything context-switching or FreeRTOS. I have used the SWI for operations that must be done a privileged mode since the application runs in user-mode. This is not really needed for smaller ARM-controller. If the application runs in supervisor-mode as in the FreeRTOS example you do not need SWI for i.e. enabling/disabling IRQ on core-level. With "garbage collection" I expect you mean the unused code removal feature. For this you just need: - make sure the vectors are not removed (KEEP in linker-script) - either ENTRY must be given in linker-script or the init-functions must be located in a section that is used with KEEP - make sure the "wildcard" is in the linker-script for the section (i.e. not just *(.text) but *(.text .text.*), same for data, rodata, bss - add -ffunction-sections to the compiler-options - add -gc-sections to the linker options (when called from the frontend with -Wl,--gc-sections For "vectors in RAM": - place the vector-implementation in the working code into an extra section (usually by using the .section diretive in the source-code) - make sure this section is linked to the .data-segment as first entry for .data in the linker-script with this the linker will reserve space for the vectors and the startup-code will copy them into RAM - remap (see AT91 datasheet) See examples from the Atmel software-package might show this better than my over-complicated gamma-example. > So now, I'm a little bit lost. I attached the files That I have modified > to get the freertos demo working. The main problem should be the swi-handling. FreeRTOS needs it but you code uses it for something else. > is there somebody that can take a look at this ? or get something > similar that he want to share ? I just had a quick look into your code. Sorry, no time to modify it as needed but it might be easier to modify the original FreeRTOS example for the additional features. Hope this helps at least a little bit. Martin
Posted on: 2009-04-06 14:44
Hi, This is more than with need for the explanation. We got it running. We are just not much familiar in the startup files... Now we are :P We have correctly redirected the SWI handling in RAM with the remap feature. So now we have something functionnal. I'll like to tell you that your explanation are always precise, exact and educative ! continue your great work Jonathan
