Posted on: 2009-03-26 12:34
Hi, Let me start by presenting my problem, and then hopefully someone can give some guidance on how to approach it :) I am working with a Keil MCB2300 board with SD interface (which I configured by using the code from Martin Thomas and ChaN's FAT-Module). I also have a GSM modem connected to the UART port, from which I receive an update on the firmware. This update (hex file) is stored into the SD card, and at this point I am supposed to do an upgrade of the firmware (my application is bare-metal, at this point I am not using any embedded OS). Could you give me some hints on which steps would you follow in order to perform the upgrading? Any input that you can provide would be more than welcome. Many thanks in advance! Kind regards, Jeroen
Posted on: 2009-03-26 15:51
I have played a little bit with update from SD-card with other controllers and this ist the basic concept I have used: - Try to add some extra checksum/crc/similar and version information in a second file or use a extra record in the hex-file. In my experiments I have used a "metadatafile" with CRC16-Checksum, Version, Numb. of bytes and filename of a binary file on the card which contains the application's code. I have used raw-binary to avoid parsing of hex-files in the firmware. Some kind of Bootloader with functions to read and browse the SD-card should be installed at the start-address of the internal flash. The real application is located "behind" this. Bootloader: - retrieve the version of the current version, could be a number located at a "fixed" address - browse the files on sd-card to find the latest firmware code-version - if latest firmware on card ist same or older than the on ein flash, continue normal operation - no newer version available verify that the checksum/crc of the file on the card is correct - if correct start the update procedure, if not jump to main application - update procedure: parse the content of the hex-file and convert it in binary-data, upload the binary data to the internal flash using the IAP functions documented in the LPC23xx manual. Keep the memory layout in mind (sectors, pages). Write the version to the "fixed" address. The main application should copy it's exceptions vectors in RAM and Remap since the start of the flash is already occupied by the exceptions vectors of the Bootloader. The main application should be linked to an adress behind the bootloader. The bootloader can be started from the main application by watchdog-reset or maybe by a simple "branch to 0x0" Hope this give at least a rough idea.
