Forum: FPGA, VHDL & Verilog Microblaze - problem with reading from user logic input
Author: Tobi (Guest)
Hi there
I am trying to link some custom made logic to my microblaze processor.
Apparently it is not working (who would have guessed so? :D ) and I
wondered if the C code I am using is correct.
int *userlogicaddress;
userlogicaddress=(int *)XPAR_USERLOGICREADING_0_BASEADDR;
dummy = *userlogicaddress; //reading from base address into dummy
XGpio gpPB;
XGpio_Initialize(&gpPB, XPAR_LEDS_8BIT_DEVICE_ID);  //setting led output port
XGpio_SetDataDirection(&gpPB, 1, 0x00000000); // setting led port output direction
XGpio_DiscreteWrite(&gpPB, 1, dummy); // writing dummy from inputs to leds
The custom logic currently contains only one latch. "Q" side of the
latches is connected to the databus the "D" side to pins which are
connected to dip switches. "G" is linked to Bus2IP_RdCE
It is basically an inital try to read the state of the dip switches into
the processor. (I know there are easier ways of doing this but it is
just an inital start - the logic will become more complex later on).
As the custom logic only contains 1 32-bit data register I assume that
the base address is the correct one to work with.
Is there any obviours error in accessing the register? If not I have to
dig a bit deeper need to look in the VHDL files or the mdp file.
Cheers
 Tobi
Author: Martin R. (herki)
Hi Tobi
Sorry for my bad english.
The instructrions are right. But u have to arrange it in another order.
First of all u have to init the XGpio showing in following code:
XGpio gpPB;
port
direction
while (1)
leds
At the moment i can not test this code, cause i dont have any
Microblaze-licence. Sorry.
Hope i could help u a little bit
Greetings
Martin
Author: Lewis (Guest)
Hi there,
could someone please help, what I am trying to do is to read registers
on the FPGA on the Spartan 3E starter kit with C implimented code on the
Microblaze then perform some arithmatic and return the result back in
another register on the FPGA.
I dont know where to start, and would be ever so greatful for some help,
Lewis
  • [vhdl]VHDL code[/vhdl]
webmaster@embdev.netContactAdvertising on EmbDev.net
