I am trying to get signalyzer lite to work with openocd and eclipse. I installed the drivers and the device shows up under device manager usb controllers and the virtual com port also. I configure under external tools and run it. This is what I get: Open On-Chip Debugger 1.0 (2009-02-14-12:53) svn:1372 BUGS? Read http://svn.berlios.de/svnroot/repos/openocd/trunk/BUGS $URL: svn://svn.berlios.de/openocd/trunk/src/openocd.c $ Error: unable to open ftdi device: 2 Error: ListDevices: 2 Error: 0: "Signalyzer LITE A" Error: 1: "Signalyzer LITE B" Runtime error, file "command.c", line 456: the cfg file is: #interface interface ft2232 ft2232_device_desc "Signalyzer A" ft2232_layout signalyzer ft2232_vid_pid 0x0403 0xbca1 I tried openocd 717 and same thing. help!
Hello Chris, I could imagine that your fault is the following line: ft2232_device_desc "Signalyzer A" Do you have a LITE version? In this case try: ft2232_device_desc "Signalyzer LITE A" Only an idea... Regards, Michael
Michael, The errors are different now. Error: ft2232.c:1419 ft2232_init_ftd2xx(): unable to open ftdi device: 2 Error: ft2232.c:1434 ft2232_init_ftd2xx(): ListDevices: 2 Error: ft2232.c:1436 ft2232_init_ftd2xx(): 0: Signalyzer LITE B Error: ft2232.c:1436 ft2232_init_ftd2xx(): 1: ˜b? If I try Signalyzer LITE B then I don't get these errors but errors trying to read bytes. Chris
I think the PID is wrong. Here is my interface config for Signalyzer:
interface ft2232 ft2232_layout signalyzer ft2232_vid_pid 0x0403 0xbca0 ft2232_device_desc "Signalyzer LITE A" |
