Forum: ARM programming with GCC/GNU tools embedding C source in the disassembler window
von Alan R. (rousea)
Anglia Electronics kindly sent me an Eclipse version of the STM32demo
project. It includes a custom makefile, so it doesn't use any outside
resource such as Solaris to create the makefile.
I am trying to create my own project to emulate this with good success
so far. In my project I am using Solaris to create the makefile for me,
so I can add or delete modules at will without having to modify the
makefile each time.
However, when I compile the Anglia version of the project the Eclipse
disassembly window shows each line of source code, followed by the
assembler code generated. When I step through the code the source window
and the disassembly window track logically.
My project does not include the relevant source code line in the
disassembly. Furthermore, if I step through the code the 'cursor' in the
source code window follows approximately where it should be, but may
jump backwards or forward several lines each time I step.
Examining my disassemby explains the jumping, since the code is not
totally logical. For example, if I have a sequence of lines setting
variables to specific values the code is likely to load each value in
turn to different r registers, then write each r register in turn to the
relevant memory address. The same code in the Anglia version would load
the first value into an r register, then copy it to the relevant memory
address, then proceed to the next variable.
Can anyone help in identifying how to configure the compiler to create
logical code, and embed source code into the disassembly listing? I
suspect the difference must be within the makefile, since this invokes
gcc, but all my switches are the same as those in the original. From
searching the web I suspect I need to invoke objdump somewhere.
Regards
von Andreas S. (andreas) (Admin)
The reason for the reordering of the code is the compiler optimization.
You are probably using -O2 or -O3, try a lower optimization level (-O1)
or disable optimization completely (-O0) if the reordering bothers you
and you can live with (slightly) slower/bigger code.
You can generate an assembler listing with embedded C source code by
running objdump with the options -dS. Not sure if that's the way to do
it so that Eclipse understands it, but can't you just compare your
Makefile to the Anglia Makefile to see how it calls gcc/objdump/...?
von M.Bubestinger (Guest)
Hi rousea ,
I don't have an answer to you question, but is it possible for you to
upload the project template from anglia? At the moment I'm evaluating
Crossworks, but i'm not very happy with it. My Problem is I can't get
Eclipse working for me :(.I would be happy to see some samples for
organizing a project with eclipse
Regards
Michael
Hi
Thanks for the reply.
Both my project and the original Anglia project invoke the gcc compile
with the flag -Os, so that can't explain the difference between the two
resultant disassembly listings.
I have attached the Anglia makefile in case you can decipher how it is
using objdump.  In Eclipse I have configured Project\Properties\C/C++
Build\Settings\Tool Settings to add the required flags to the Solaris
compiler and linker. After compiler each project I have looked in the
console window to see the command strings invoked and confirmed that the
gcc flags are virtually the same.  There are differences, but they
relate to the different folder structure I use to store the .c and .h
modules.
I originally had the text "objcopy -O srec Mega_Link.elf Mega_Link.s19"
in the Build Steps\Post Build Steps\Command window (Mega_Link being the
name of my project).  I tried changing this to "objcopy -O srec
Mega_Link.elf Mega_Link.s19; objdump -dS Mega_Link.elf".  During
compilation streams of disassembly code scroll through the console
window, but when it has finished and I launch the project, the contents
of the Disassembly window are the same as before.
I am obviously not using objdump correctly, Can you give any further
ideas?
Regards
I do not fully understand what you mean with "Solaris compiler and
linker" but did you double-check that -g is in your "Tool Settings"
command-line options?
Thanks for your comments.
I myself am very confused about the build variant I am using.  It took
an exceptionally long time for me to get the IDE, compiler and debugger
to work.  I initially downloaded Eclipse Gannymede, but was unable to
compile of debug the project.  I followed instructions on numerous
websites to try to fix this.  As far as I remember I downloaded Zylin,
Cygwin, gdb, CodeSourcery and Solaris.  Some of these are build variants
of gcc, some are add-ons for Eclipse.  Eventually I got a combination
that works.  Ideally I would like to start again with a build that just
includes the add-ons I need to do the job, but I am afraid that I will
have difficulty unless someone can give be concise instructions of how
to build Eclipse and gcc to develop and debug software for an Arm Cortex
processor.
The console window shows that the commands used to build each module are
typically:
gcc -nostdinc -DLCD_ILI9320 -DSTM32F103x8B
-IC:/Software/Mega_Link/Mega_Link/Include -Os -g3 -Wall -c -mthumb
-march=armv7-m -ffunction-sections -fdata-sections -Wno-pointer-sign -o
Source\usb_endp.o ..\Source\usb_endp.c
and the linker command is:
gcc -nostartfiles -LC:\cygwin\lib\gcc\arm-eabi\4.2.3\thumb -mthumb
-march=armv7-m -Tstm32rom.ld
-Wl,-Map=obj\Mega_Link.map,-cref,--gc-sections -ggdb -oMega_Link.elf
usb\src\usb_regs.o .... Source\IO.o
You will see that the compiler includes -g3 and -Os, which I believe
together define the output format.  However, I have tried all
combinations of these flags without success.  The above setting produce
code that works, but is not easy to follow against the source.
Regards
von mthomas (Guest)
No out-of-the-box solution but some suggestions/remarks:
The command lines just show gcc, the CS cross-toolchain uses the prefix
arm-non-eabi so arm-none-eabi-gcc should be there. Are there any
symbolic- or hard-links set? But maybe you are still using the toolchain
from the Anglia package, IRC they do not use a prefix.
I usually use -gdwarf-2 but have to admit that I have never played with
the -g options. So you may try -gdwarf-2 or just -g instead of -g3 and
-ggdb.
The optimization setting (-O) should not have any influence on the
generation for debug-information.
You should not use or need to use absolute pathes like ...\thumb when
using the frontend (arm-none-eabi-gcc) for linking and a rahter new
build of the toolchain.
Remove the options -ffunction-sections, -fdata-sections and
--gc-sections for now; can be added later once everything else is
running.
I still not not get what you mean with "Solaris". If it's the OS from
SUN I don't see how this is related to the problem.
"cross-gdb" is included in the CS package (arm-none-eabi-gdb), no extra
download needed. The CDT GDB hardware debugging plugin can be used
instead of the Zylin plugin. But in the OpenOCD mailing-list there have
been reports about problems with the gdb in current version of CS G++
lite for ARM. Not sure, please search the OpenOCD mailing-list archive.
Like M.Bubestinger I'm interested in the package that has been sent from
Anglia. Please ask them for permission so you may attach it to a
message. (S. "ntfreak" O.: do you read?)
Thanks for your response.  I have asked Anglia for permission to forward
you their project.  I obviously can't respond to you until I have their
reply and I have had time to digest all your comments.  Since it is now
Friday evening it will take a few days, but I will reply.
Regards
Hi
I have attached the Eclipse configuration sent by Anglia. However, I
must have changed something on my system, because it now fails at the
end of compilation with the message 'cannot open map file
obj\stm32demo.map'
I am now getting extremely frustrated with Eclipse.  I want to use it as
a tool for developing a project to run on embedded hardware, but I am
spending more time trying to fix the tool than I am spending developing
the project!
I sincerely hope that someone somewhere can come up with a foolproof
method of building Eclipse with all the necessary plug-ins so it can be
used to develop projects running on ARM Cortex targets.
Incidentally, at some stage I stumbled across Solaris as a tool for
constructing the compilation.  The attachment includes some screeshots
that show the options presented for the compiler and linker.  I have not
found any other means of easily configuring the project properties.
von mthomas (Guest)
I don't think the "Solaris C Compiler support" is the best solution.
There is a arm-gcc plugin for Eclipse available at sf.net but since I'm
using Eclipse with a self-made makefile I can not provide additional
information on this plugin. I suggest that you use a makefile too. There
are tutorials from Jim Lynch (google for them) which explain the setup
with an external makefile. Once you have the building working you can
turn to the debugging with a gdb-server (i.e. OpenOCD). Another option
might be to buy a commercial solution. AFIAK Codesourcery offers
Eclipse-support in the "non-lite" versions for CS G++ for ARM. Sorry, I
can not offer a foolproof solution. I'm using Eclipse as Editor and
Debugger (with OpenOCD) but did not have the time to write a "guide".
Anyway my setup for building (not debugging) is very similar to the one
described by Jim Lynch.
Martin
I am extremely appreciative of the effort you have taken to give a
comprehensive response, and would like to thank you for it.
I have found the articles published by Jim Lynch.  In fact I had seen
them some time ago, but I had discounted them because they don't
encompass ARM Cortex. They were written around 2005, before the release
of Cortex.  The same applies to YAGARTO, but their website specifically
states that it does not cover Cortex.  I assume from this that
incorporating Cortex is not a trivial task.
I guess my objective of implementing a variant of Eclipse that
automatically creates the makefile should not be regarded as essential.
However, the work I have done to date with the Solaris add-on proves to
be a great benefit where new modules are added as the project evolves.
It saves time when I don't have to keep modifying the makefile to
accommodate the changes.
The implementation of Eclipse that I now have is compatible with Cortex
and allows me to download a debug the software on my target.  However,
the shortcomings are:
1) It does not step through code logically, and doesn't embed the C
source within the disassembler
2) It doesn't include library functions (e.g. ctype.h)
3) After all my abortive efforts I don't know how I eventually built it,
so can't replicate it on another computer.
Regards
