Forum: ARM programming with GCC/GNU tools Link order of objects / Linker script
Author: Joe Dupre (jdupre)
Is it "normal" to have to specify the order of .o files when linking?
I have just encountered some sample code where the ARM startup assembly
code object file must be first in the list of files to be linked.  (If
not, the code will not run.)  Other sample code doesn't seem to care
what order the files are linked.
Is is a function if the linker script to tell the linker where to put
certain object files?
The order has an impact but it's usually not a good idea to create code
that depends on the order. Usage of libraries (.a-files) might be
excpetion in certain scenarios. Are there any weak
defintions/attributes? Are symbols used in the startup-code which are
also used in other files?
Please check the map-files for the both cases, you should see
differences esp. in the cross-reference. If you have difficulties to
interpret them you can pack the two map-files into a zip-file and attach
it to a message. Maybe the readers of the forum can help. Without a
little more information it's difficult to help.
This is somehow possible but it's not a "where to put object files" but
where to put the sections defined in the object file.
The problem was that the arm boot code, including the reset handler, was
assigned to the .text section, not the .startup section.  Therefore if
bootcode.s was linked first, everything was fine.  (I thought the ENTRY
declaration would handle this, but apparently not.)
[I had converted the project from a make project to an eclipse project,
so the linker object order got re-arranged.]
