Forum: ARM programming with GCC/GNU tools Error using WinARM
Author: Vidya Ozarde (vidya11)
Hi
I am working with winarm on vista.
So I downloaded the winarm20060606 and installed it, and opened the
programmers notepad from the pn folder and loaded a example project and
clicked "make All"
i get this message which is as follows:
> "make.exe" all
-------- begin (mode: ROM_RUN) --------
arm-elf-gcc (GCC) 4.1.1 (WinARM)
Copyright (C) 2006 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is
NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR
PURPOSE.
Assembling (ARM-only): startup.S
arm-elf-gcc -c -mcpu=arm7tdmi  -I. -x assembler-with-cpp -DROM_RUN
-Wa,-adhlns=startup.lst,-gdwarf-2 startup.S -o startup.o
arm-elf-gcc: CreateProcess: No such file or directory
make.exe: *** [startup.o] Error 1
> Process Exit Code: 2
> Time Taken: 00:00
Could you please tell me how to remove the error?
Author: Jim Kaz (ancaritha)
>> Time Taken: 00:00
Did you add WinArm to your system path?  Also, I seem to recall a bug in
GCC 4.1.0 (the version that comes in WinArm20060606) and it won't run on
Vista.
>>> Time Taken: 00:00
> Vista.
There is a dirty hack to get the older tools as in WinARM working with
Vista. It's mentioned on the WinARM page. But I suggest to use a package
with newer versions (DevkitARM, Anglia SARM, Yagarto, Codesourcery G++
for ARM...) which should work "out of the box".
