Forum: ARM programming with GCC/GNU tools JTAG Comm Failure with Comstick
von Stelios M. (styl)
Hi everyone, Happy new year.
I an new in ARM controllers, starting with comStick from Hitex.
I want to use Eclipse for development.
My PC is running XP with driver "STR9_comStick_usb.sys" for
USB_Serial_JTAG from Hitex.
The comStick is tested with hitop, the Flash is programmed and is
running a programme, blinking the LED.
In the eclipse environment, I just want to start running the flashed
programme, so I run the following script with OpenOCD:
#log_output cs.log
debug_level 3
#daemon configuration
telnet_port 4444
gdb_port 3333
interface ft2232
ft2232_device_desc "STR9-comStick A"
ft2232_layout comstick
#ft2232_layout usbjtag
ft2232_vid_pid 0x0640 0x002C
jtag_speed 3
#jtag_speed 1
jtag_nsrst_delay 100
jtag_ntrst_delay 100
#use combined on interfaces or targets that can't set TRST/SRST
separately
reset_config trst_and_srst
#jtag scan chain
#format L IRC IRCM IDCODE (Length, IR Capture, IR Capture Mask, IDCODE)
jtag_device 8 0x1 0x1 0xfe
jtag_device 4 0x1 0xf 0xe
jtag_device 5 0x1 0x1 0x1e
#target configuration
daemon_startup reset
#target <type> <startup mode>
#target arm966e <endianness> <reset mode> <chainpos> <variant>
target arm966e little run_and_init 1 arm966e
run_and_halt_time 0 50
working_area 0 0x50000000 32768 nobackup
#flash bank <driver> <base> <size> <chip_width> <bus_width>
flash bank str9x 0x00000000 0x00080000 0 0 0
flash bank str9x 0x00080000 0x00008000 0 0 0
#Script used for FLASH programming
target_script 0 reset str91x_reset.script
I get the following debug log:
Open On-Chip Debugger (2008-06-19 19:00) svn: 717
URL: http://svn.berlios.de/svnroot/repos/openocd/trunk
Debug:   6 0 command.c:432 command_run_line(): telnet_port 4444
Debug:   8 0 command.c:432 command_run_line(): gdb_port 3333
Debug:   10 0 command.c:432 command_run_line(): interface ft2232
Debug:   12 0 command.c:432 command_run_line(): ft2232_device_desc
"STR9-comStick A"
Debug:   14 10 command.c:432 command_run_line(): ft2232_layout comstick
Debug:   16 10 command.c:432 command_run_line(): ft2232_vid_pid 0x0640
0x002C
Debug:   18 390 command.c:432 command_run_line(): jtag_speed 60
Debug:   19 390 jtag.c:1863 handle_jtag_speed_command(): handle jtag
speed
Info:    20 390 options.c:50 configuration_output_handler(): jtag_speed:
60, 60
Debug:   22 390 command.c:432 command_run_line(): jtag_nsrst_delay 100
Debug:   24 390 command.c:432 command_run_line(): jtag_ntrst_delay 100
Debug:   26 390 command.c:432 command_run_line(): reset_config
trst_and_srst
Debug:   28 390 command.c:432 command_run_line(): jtag_device 8 0x1 0x1
0xfe
Debug:   30 390 command.c:432 command_run_line(): jtag_device 4 0x1 0xf
0xe
Debug:   32 390 command.c:432 command_run_line(): jtag_device 5 0x1 0x1
0x1e
Debug:   34 390 command.c:432 command_run_line(): daemon_startup reset
Info:    35 390 options.c:50 configuration_output_handler(): Open
Debug:   37 390 command.c:432 command_run_line(): target arm966e little
Debug:   38 390 arm966e.c:142 arm966e_target_command(): chain_pos: 1,
variant: arm966e
Debug:   40 390 command.c:432 command_run_line(): run_and_halt_time 0 50
Debug:   42 390 command.c:432 command_run_line(): working_area 0
Debug:   44 390 command.c:432 command_run_line(): flash bank str9x
Debug:   46 390 command.c:432 command_run_line(): flash bank str9x
Debug:   48 390 command.c:432 command_run_line(): target_script 0 reset
str91x_reset.script
Debug:   50 390 command.c:432 command_run_line(): init
Debug:   51 400 openocd.c:102 handle_init_command(): target init
complete
Debug:   52 400 ft2232.c:1374 ft2232_init_ftd2xx(): 'ft2232' interface
using FTD2XX with 'comstick' layout (0640:002c)
Debug:   53 520 ft2232.c:1463 ft2232_init_ftd2xx(): current latency
timer: 2
Debug:   54 520 ft2232.c:1962 comstick_init(): 80 08 0b
Debug:   55 520 ft2232.c:1982 comstick_init(): 82 03 03
Debug:   56 520 ft2232.c:253 ft2232_speed(): 86 3c 00
Debug:   57 560 openocd.c:109 handle_init_command(): jtag interface init
complete
Debug:   58 560 jtag.c:1537 jtag_init_inner(): Init JTAG chain
Debug:   59 560 jtag.c:326 jtag_call_event_callbacks(): jtag event: JTAG
controller reset (TLR or TRST)
Debug:   60 560 jtag.c:1295 jtag_reset_callback(): -
Debug:   61 560 jtag.c:1295 jtag_reset_callback(): -
Debug:   62 560 jtag.c:1295 jtag_reset_callback(): -
Debug:   63 560 jtag.c:326 jtag_call_event_callbacks(): jtag event: JTAG
Debug:   64 560 jtag.c:1295 jtag_reset_callback(): -
Debug:   65 560 jtag.c:1295 jtag_reset_callback(): -
Debug:   66 560 jtag.c:1295 jtag_reset_callback(): -
Error:   67 580 jtag.c:1351 jtag_examine_chain(): JTAG communication
failure, check connection, JTAG interface, target power etc.
Error:   68 580 jtag.c:1556 jtag_init_inner(): trying to validate
configured JTAG chain anyway...
Debug:   69 580 jtag.c:326 jtag_call_event_callbacks(): jtag event: JTAG
Debug:   70 580 jtag.c:1295 jtag_reset_callback(): -
Debug:   71 580 jtag.c:1295 jtag_reset_callback(): -
Debug:   72 580 jtag.c:1295 jtag_reset_callback(): -
Error:   73 580 jtag.c:1444 jtag_validate_chain(): Error validating JTAG
scan chain, IR mismatch, scan returned 0x07ffff
Debug:   74 591 jtag.c:326 jtag_call_event_callbacks(): jtag event: JTAG
Debug:   75 591 jtag.c:1295 jtag_reset_callback(): -
Debug:   76 591 jtag.c:1295 jtag_reset_callback(): -
Debug:   77 591 jtag.c:1295 jtag_reset_callback(): -
Error:   78 591 jtag.c:1444 jtag_validate_chain(): Error validating JTAG
Debug:   79 601 jtag.c:326 jtag_call_event_callbacks(): jtag event: JTAG
Debug:   80 601 jtag.c:1295 jtag_reset_callback(): -
Debug:   81 601 jtag.c:1295 jtag_reset_callback(): -
Debug:   82 601 jtag.c:1295 jtag_reset_callback(): -
Error:   83 601 jtag.c:1444 jtag_validate_chain(): Error validating JTAG
Debug:   84 611 jtag.c:326 jtag_call_event_callbacks(): jtag event: JTAG
Debug:   85 611 jtag.c:1295 jtag_reset_callback(): -
Debug:   86 611 jtag.c:1295 jtag_reset_callback(): -
Debug:   87 611 jtag.c:1295 jtag_reset_callback(): -
Error:   88 611 jtag.c:1444 jtag_validate_chain(): Error validating JTAG
Debug:   89 621 jtag.c:326 jtag_call_event_callbacks(): jtag event: JTAG
Debug:   90 621 jtag.c:1295 jtag_reset_callback(): -
Debug:   91 621 jtag.c:1295 jtag_reset_callback(): -
Debug:   92 621 jtag.c:1295 jtag_reset_callback(): -
Error:   93 621 jtag.c:1444 jtag_validate_chain(): Error validating JTAG
Debug:   94 651 jtag.c:326 jtag_call_event_callbacks(): jtag event: JTAG
Debug:   95 651 jtag.c:1295 jtag_reset_callback(): -
Debug:   96 651 jtag.c:1295 jtag_reset_callback(): -
Debug:   97 651 jtag.c:1295 jtag_reset_callback(): -
Error:   98 661 jtag.c:1444 jtag_validate_chain(): Error validating JTAG
Error:   99 661 jtag.c:1565 jtag_init_inner(): Could not validate JTAG
chain, exit
Debug:   100 661 jtag.c:1581 jtag_init_reset(): Trying to bring the JTAG
controller to life by asserting TRST / TLR
Debug:   101 661 jtag.c:996 jtag_add_reset(): SRST line released
Debug:   102 661 jtag.c:1015 jtag_add_reset(): TRST line asserted
Debug:   103 661 jtag.c:326 jtag_call_event_callbacks(): jtag event:
JTAG controller reset (TLR or TRST)
Debug:   104 661 jtag.c:1295 jtag_reset_callback(): -
Debug:   105 661 jtag.c:1295 jtag_reset_callback(): -
Debug:   106 661 jtag.c:1295 jtag_reset_callback(): -
Debug:   107 661 jtag.c:992 jtag_add_reset(): SRST line asserted
Debug:   108 661 jtag.c:1015 jtag_add_reset(): TRST line asserted
Debug:   109 661 jtag.c:326 jtag_call_event_callbacks(): jtag event:
Debug:   110 661 jtag.c:1295 jtag_reset_callback(): -
Debug:   111 661 jtag.c:1295 jtag_reset_callback(): -
Debug:   112 661 jtag.c:1295 jtag_reset_callback(): -
Debug:   113 661 jtag.c:992 jtag_add_reset(): SRST line asserted
Debug:   114 661 jtag.c:996 jtag_add_reset(): SRST line released
Debug:   115 661 ft2232.c:1111 comstick_reset(): trst: 1, srst: 0,
high_output: 0x02, high_direction: 0x03
Debug:   116 771 ft2232.c:1111 comstick_reset(): trst: 1, srst: 1,
high_output: 0x00, high_direction: 0x03
Debug:   117 771 ft2232.c:1111 comstick_reset(): trst: 0, srst: 1,
high_output: 0x01, high_direction: 0x03
Debug:   118 931 ft2232.c:1111 comstick_reset(): trst: 0, srst: 0,
high_output: 0x03, high_direction: 0x03
Debug:   119 1151 jtag.c:1537 jtag_init_inner(): Init JTAG chain
Debug:   120 1151 jtag.c:326 jtag_call_event_callbacks(): jtag event:
Debug:   121 1151 jtag.c:1295 jtag_reset_callback(): -
Debug:   122 1151 jtag.c:1295 jtag_reset_callback(): -
Debug:   123 1151 jtag.c:1295 jtag_reset_callback(): -
Debug:   124 1151 jtag.c:326 jtag_call_event_callbacks(): jtag event:
Debug:   125 1151 jtag.c:1295 jtag_reset_callback(): -
Debug:   126 1151 jtag.c:1295 jtag_reset_callback(): -
Debug:   127 1151 jtag.c:1295 jtag_reset_callback(): -
Error:   128 1151 jtag.c:1351 jtag_examine_chain(): JTAG communication
Error:   129 1151 jtag.c:1556 jtag_init_inner(): trying to validate
Debug:   130 1151 jtag.c:326 jtag_call_event_callbacks(): jtag event:
Debug:   131 1151 jtag.c:1295 jtag_reset_callback(): -
Debug:   132 1151 jtag.c:1295 jtag_reset_callback(): -
Debug:   133 1151 jtag.c:1295 jtag_reset_callback(): -
Error:   134 1161 jtag.c:1444 jtag_validate_chain(): Error validating
JTAG scan chain, IR mismatch, scan returned 0x07ffff
Debug:   135 1191 jtag.c:326 jtag_call_event_callbacks(): jtag event:
Debug:   136 1191 jtag.c:1295 jtag_reset_callback(): -
Debug:   137 1191 jtag.c:1295 jtag_reset_callback(): -
Debug:   138 1191 jtag.c:1295 jtag_reset_callback(): -
Error:   139 1191 jtag.c:1444 jtag_validate_chain(): Error validating
Debug:   140 1201 jtag.c:326 jtag_call_event_callbacks(): jtag event:
Debug:   141 1201 jtag.c:1295 jtag_reset_callback(): -
Debug:   142 1201 jtag.c:1295 jtag_reset_callback(): -
Debug:   143 1201 jtag.c:1295 jtag_reset_callback(): -
Error:   144 1201 jtag.c:1444 jtag_validate_chain(): Error validating
Debug:   145 1211 jtag.c:326 jtag_call_event_callbacks(): jtag event:
Debug:   146 1211 jtag.c:1295 jtag_reset_callback(): -
Debug:   147 1211 jtag.c:1295 jtag_reset_callback(): -
Debug:   148 1211 jtag.c:1295 jtag_reset_callback(): -
Error:   149 1211 jtag.c:1444 jtag_validate_chain(): Error validating
Debug:   150 1231 jtag.c:326 jtag_call_event_callbacks(): jtag event:
Debug:   151 1231 jtag.c:1295 jtag_reset_callback(): -
Debug:   152 1231 jtag.c:1295 jtag_reset_callback(): -
Debug:   153 1231 jtag.c:1295 jtag_reset_callback(): -
Error:   154 1261 jtag.c:1444 jtag_validate_chain(): Error validating
Debug:   155 1271 jtag.c:326 jtag_call_event_callbacks(): jtag event:
Debug:   156 1271 jtag.c:1295 jtag_reset_callback(): -
Debug:   157 1271 jtag.c:1295 jtag_reset_callback(): -
Debug:   158 1271 jtag.c:1295 jtag_reset_callback(): -
Error:   159 1271 jtag.c:1444 jtag_validate_chain(): Error validating
Error:   160 1271 jtag.c:1565 jtag_init_inner(): Could not validate JTAG
chain, exit
Debug:   161 1271 openocd.c:126 handle_init_command(): flash init
complete
Debug:   162 1271 openocd.c:130 handle_init_command(): NAND init
complete
Debug:   163 1271 openocd.c:134 handle_init_command(): pld init complete
Debug:   164 1312 gdb_server.c:2036 gdb_init(): gdb service for target
arm966e at port 3333
Debug:   166 1332 command.c:432 command_run_line(): reset
Debug:   167 1342 target.c:1851 handle_reset_command(): -
Debug:   168 1342 ft2232.c:253 ft2232_speed(): 86 3c 00
Debug:   169 1342 jtag.c:1581 jtag_init_reset(): Trying to bring the
JTAG controller to life by asserting TRST / TLR
Debug:   170 1342 jtag.c:996 jtag_add_reset(): SRST line released
Debug:   171 1342 jtag.c:1015 jtag_add_reset(): TRST line asserted
Debug:   172 1342 jtag.c:326 jtag_call_event_callbacks(): jtag event:
Debug:   173 1342 jtag.c:1295 jtag_reset_callback(): -
Debug:   174 1342 jtag.c:1295 jtag_reset_callback(): -
Debug:   175 1342 jtag.c:1295 jtag_reset_callback(): -
Debug:   176 1342 jtag.c:992 jtag_add_reset(): SRST line asserted
Debug:   177 1342 jtag.c:1015 jtag_add_reset(): TRST line asserted
Debug:   178 1342 jtag.c:326 jtag_call_event_callbacks(): jtag event:
Debug:   179 1342 jtag.c:1295 jtag_reset_callback(): -
Debug:   180 1342 jtag.c:1295 jtag_reset_callback(): -
Debug:   181 1342 jtag.c:1295 jtag_reset_callback(): -
Debug:   182 1342 jtag.c:992 jtag_add_reset(): SRST line asserted
Debug:   183 1342 jtag.c:996 jtag_add_reset(): SRST line released
Debug:   184 1342 ft2232.c:1111 comstick_reset(): trst: 1, srst: 0,
Debug:   185 1442 ft2232.c:1111 comstick_reset(): trst: 1, srst: 1,
Debug:   186 1442 ft2232.c:1111 comstick_reset(): trst: 0, srst: 1,
Debug:   187 1552 ft2232.c:1111 comstick_reset(): trst: 0, srst: 0,
Debug:   188 1772 jtag.c:1537 jtag_init_inner(): Init JTAG chain
Debug:   189 1772 jtag.c:326 jtag_call_event_callbacks(): jtag event:
Debug:   190 1772 jtag.c:1295 jtag_reset_callback(): -
Debug:   191 1772 jtag.c:1295 jtag_reset_callback(): -
Debug:   192 1772 jtag.c:1295 jtag_reset_callback(): -
Debug:   193 1772 jtag.c:326 jtag_call_event_callbacks(): jtag event:
Debug:   194 1772 jtag.c:1295 jtag_reset_callback(): -
Debug:   195 1772 jtag.c:1295 jtag_reset_callback(): -
Debug:   196 1772 jtag.c:1295 jtag_reset_callback(): -
Error:   197 1772 jtag.c:1351 jtag_examine_chain(): JTAG communication
Error:   198 1772 jtag.c:1556 jtag_init_inner(): trying to validate
Debug:   199 1772 jtag.c:326 jtag_call_event_callbacks(): jtag event:
Debug:   200 1772 jtag.c:1295 jtag_reset_callback(): -
Debug:   201 1772 jtag.c:1295 jtag_reset_callback(): -
Debug:   202 1772 jtag.c:1295 jtag_reset_callback(): -
Error:   203 1782 jtag.c:1444 jtag_validate_chain(): Error validating
Debug:   204 1792 jtag.c:326 jtag_call_event_callbacks(): jtag event:
Debug:   205 1792 jtag.c:1295 jtag_reset_callback(): -
Debug:   206 1792 jtag.c:1295 jtag_reset_callback(): -
Debug:   207 1792 jtag.c:1295 jtag_reset_callback(): -
Error:   208 1792 jtag.c:1444 jtag_validate_chain(): Error validating
Debug:   209 1802 jtag.c:326 jtag_call_event_callbacks(): jtag event:
Debug:   210 1802 jtag.c:1295 jtag_reset_callback(): -
Debug:   211 1802 jtag.c:1295 jtag_reset_callback(): -
Debug:   212 1802 jtag.c:1295 jtag_reset_callback(): -
Error:   213 1802 jtag.c:1444 jtag_validate_chain(): Error validating
Debug:   214 1812 jtag.c:326 jtag_call_event_callbacks(): jtag event:
Debug:   215 1812 jtag.c:1295 jtag_reset_callback(): -
Debug:   216 1812 jtag.c:1295 jtag_reset_callback(): -
Debug:   217 1812 jtag.c:1295 jtag_reset_callback(): -
Error:   218 1812 jtag.c:1444 jtag_validate_chain(): Error validating
Debug:   219 1852 jtag.c:326 jtag_call_event_callbacks(): jtag event:
Debug:   220 1852 jtag.c:1295 jtag_reset_callback(): -
Debug:   221 1852 jtag.c:1295 jtag_reset_callback(): -
Debug:   222 1852 jtag.c:1295 jtag_reset_callback(): -
Error:   223 1852 jtag.c:1444 jtag_validate_chain(): Error validating
Debug:   224 1862 jtag.c:326 jtag_call_event_callbacks(): jtag event:
Debug:   225 1862 jtag.c:1295 jtag_reset_callback(): -
Debug:   226 1862 jtag.c:1295 jtag_reset_callback(): -
Debug:   227 1862 jtag.c:1295 jtag_reset_callback(): -
Error:   228 1862 jtag.c:1444 jtag_validate_chain(): Error validating
Error:   229 1862 jtag.c:1565 jtag_init_inner(): Could not validate JTAG
chain, exit
After that, the comstick starts running, but as you can see, there is no
proper connection with the JTAG.
Could be of any help changing the USB driver? Is there any mistake in
the script? Can anyone help me?
Thanks
Styl
von Spencer O. (ntfreak)
> Thanks
> Styl
script looks ok to me.
Try a newer version of openocd - should work but your version is quite
old.
Before you attempt to program, you need to get the connection working
first so try reset_halt rather than run_and_halt.
The script will need updating for the newer openocd, but there are
examples in the target/target dir of openocd.
Cheers
Spen
>> Thanks
>> Styl
> old.
Dear Spen, Thank you for your reply.
Where can I find a more recent version of opeocd?
I got the 717 version of opeocd from Yagarto.
Styl
von Alois S. (alois1505)
>>> Thanks
>>> Styl
>> old.
> Styl
Hi Stelios,
thanks for your posting, your script is the solution for me. I adapted
my configuration with your changes and I got my comStick working.
I have the same version of OCD as you!
von Axel Bepperling (Guest)
I am also new to ARM programming and I also bought some STR9-comStick
from Hitex.
I modified an example that now uses the RTC interupts to increase a
counter nd does an output over UART. Unforunately, my code has
apparently some mistakes and now I cannot connect to stick anymore.
Currently I am not using OpenOCD, but the Hitop for compilation and
download and Eclipse for editing.
Is there any chance to access my comStick ever again?
I read that the stick is a bit picky on particular errors, as the JTAG
is resettet with the processor and it takes some time until JTAG gets
control.
Thanks for helping
cheers
Axel
