Forum: ARM programming with GCC/GNU tools SAM&S256 - DBGU_UART
Author: Marcin Domaszewicz (marcind)
Hi!
I have a problem with uart - when I send text I get uncorrect chars.
void dbgu_init()
  AT91S_DBGU *pDBGU = AT91C_BASE_DBGU;
  //enable pins
  *AT91C_PIOA_PDR = AT91C_PA9_DRXD | AT91C_PA10_DTXD;
  pDBGU->DBGU_CR = AT91C_US_RSTRX | AT91C_US_RSTTX |
                         AT91C_US_RXDIS |   AT91C_US_TXDIS;
        pDBGU->DBGU_MR = AT91C_US_PAR_NONE | AT91C_US_CHMODE_NORMAL;
         pDBGU->DBGU_BRGR = 78;       /* Baud Rate = 38400 */
   pDBGU->DBGU_CR = AT91C_US_RXEN  | AT91C_US_TXEN;
int dbgu_putc( int ch)
  while (!(AT91C_BASE_DBGU->DBGU_CSR & AT91C_US_TXRDY));
  return (AT91C_BASE_DBGU->DBGU_THR = ch);
void dbgu_puts(char* s)
  while ( *s ) dbgu_putc( *s++);
in main():
dbgu_init(); and dbgu("text");
On terminal I get in hex:
0xF8 0x1E 0x31
After reset received chars are diferent.
What's wrong??
Double-check if this value really is valid for the desired "38400
baud-rate" with the configured frequency (clock-source, PLL etc.).
Thanks for answer.
I have MCK = 47923200 so after divided by 16 and 38400 I get 78.
I use USART0 with this parameter and it works OK.
You might look into the AT91SAM7S-EK software-package available from
atmel.com. I have just used dbgu.h/dbgu.c from the package for the
SAM7SE-EK in a project with an AT91SAM7SE512 and it worked as expected.
Some excerpts follow but it might be better to get the original-code
from the Atmel site.
#define BOARD_MCK               48000000
#define DBGU_STANDARD           AT91C_US_PAR_NONE
int main(void)
//...PIO-configuration...
   DBGU_Configure(DBGU_STANDARD, 115200, BOARD_MCK);
//...send chars/strings using DBGU_PutChar
copied from the software-package's code:
void DBGU_Configure(unsigned int mode,
                           unsigned int baudrate,
                           unsigned int mck)
    // Reset & disable receiver and transmitter, disable interrupts
    AT91C_BASE_DBGU->DBGU_CR = AT91C_US_RSTRX | AT91C_US_RSTTX;
    AT91C_BASE_DBGU->DBGU_IDR = 0xFFFFFFFF;
    // Configure baud rate
    AT91C_BASE_DBGU->DBGU_BRGR = mck / (baudrate * 16);
    // Configure mode register
    AT91C_BASE_DBGU->DBGU_MR = mode;
    // Disable DMA channel
    AT91C_BASE_DBGU->DBGU_PTCR = AT91C_PDC_RXTDIS | AT91C_PDC_TXTDIS;
    // Enable receiver and transmitter
    AT91C_BASE_DBGU->DBGU_CR = AT91C_US_RXEN | AT91C_US_TXEN;
static void DBGU_PutChar(unsigned char c)
    // Wait for the transmitter to be ready
    while ((AT91C_BASE_DBGU->DBGU_CSR & AT91C_US_TXEMPTY) == 0);
    // Send character
    AT91C_BASE_DBGU->DBGU_THR = c;
    // Wait for the transfer to complete
I try to use Atmel code but it still doesn't work.
The only change I do I replace a line:
with
and also I wrote
//enable pins
Hi
I managed to run DBGU uart but still I have a problem because sometimes
chars are wrong, espacially when rate is high. When it is 4800 bps,
there are 20% of error. It is probably connected with wrong clocking,
but I can't find what is wrong.
Please for help
The code is:
/// Initialize Serial Interface
void dbgu_init( unsigned int baudrate)
  //enable clock
  AT91F_PMC_EnablePeriphClock ( AT91C_BASE_PMC, ( 1 << AT91C_ID_SYS ) )
  //enable RxD and TxD pin
  pDBGU->DBGU_CR = AT91C_US_RSTRX |          /* Reset Receiver      */
          AT91C_US_RSTTX |          /* Reset Transmitter   */
          AT91C_US_RXDIS |          /* Receiver Disable    */
          AT91C_US_TXDIS;           /* Transmitter Disable */
  pDBGU->DBGU_IDR = 0xFFFFFFFF;
  pDBGU->DBGU_MR = AT91C_US_PAR_NONE | AT91C_US_CHMODE_NORMAL | 0 << 15;
  pDBGU->DBGU_BRGR = AT91F_US_Baudrate(MCK,baudrate);
/* Baud Rate Divisor */
  pDBGU->DBGU_PTCR = AT91C_PDC_RXTDIS | AT91C_PDC_TXTDIS;
  pDBGU->DBGU_CR = AT91C_US_RXEN  |          /* Receiver Enable     */
          AT91C_US_TXEN;            /* Transmitter Enable  */
void dbgu_isr(unsigned int int_type)
  AT91F_AIC_ConfigureIt(AT91C_BASE_AIC,AT91C_ID_SYS,0,0,ISR_Dbgu);
  AT91F_AIC_EnableIt(AT91C_BASE_AIC,AT91C_ID_SYS);
  pDBGU->DBGU_IER = int_type;
The interrupt occurs when char is received and works as simple echo.
