Forum: ARM programming with GCC/GNU tools Integer getting placed at address not divisible by 4
Author: Vinit Bidkar (vinitbidkar)
Details: i am using Atmel's AT91SAM7X256-EK board
Compiler: IAR 5.11
Problem Summary: An 32 bit structure member int (uint32_t) is getting
placed in the memory at an adress which is not divisible by 4. Hence an
abort execption is getting generated due to misaligned read access.
Do i have to use any compiler setting to avoid this?
According to my knowledge, in an ARM 7 processor, a data type will
always be placed at a memory location which is divisible by the size of
that data type.
> Compiler: IAR 5.11
> that data type.
Additonal information:
The above mentioned structure pointer is typecasted to an array pointer.
When i create a local instance of the structure then there in problem of
misalignment.
Vinit Bidkar wrote:
>> Compiler: IAR 5.11
>> that data type.
> misalignment.
Typo
When i create a local instance of the structure then there no problem of
misalignment.
