Forum: ARM programming with GCC/GNU tools Firmware Upgrade
Author: Shripad Joshi (shripad4703)
I have been given the task of creating a bootloader for an Atmel ARM7
> processor.  >
> By bootloader I basically mean a firmware upgrade tool.  It will not
> be loading any code to RAM for execution.  Uploading of new firmware
> will be via a serial port (UART0)
> I would like to have the bootloader code in the same project as the
> application code, if possible.  That is, every time the project is
> built, it will build both the application and the bootloader.
> However, only the application part will be sent over serial port to be
> flashed when upgrading.  The bootloader part will obviously be placed
> in a seperate section of FLASH from the application.
>> processor.  >
To how many mailing-lists forums has this been posted before (">>")?
What replies did you already get?
Possible but why?
Any you may not notice dependencies between bootloader and application
until you try to create a stand-alone application without bootloader.
Can be done.
Maybe someone else sees the question(s) - I don't.
