Forum: ARM programming with GCC/GNU tools Ethernet ISR problem in AT91SAM7x256
von Ramesh K. (kpcta)
Hello All,
                   I'm using ATMEL evaluation board using the chip
AT91SAM7x256.
                       There i downloaded sample code for Emac (
Ethernet) given by ATMEL. It is working . In that packet reception as
polling . But i want to do that in EMAC Interrupt. So i called the same
Emac_poll ( ) function in EMAC RxISR.
                       I'm transmitting pkt per 20msec and pkt size is
214 bytes. From that i'm facing the problem of BNA ( Buffer Not
Available) continuously , also i cleared the BNA bit in rx register ,
but it happens continuously.
No of Rx Buffers - 16
size of each Rx Buff - 128 bytes
                        Please anyone give me your suggesion or the code
used for EMAC ISR.
Waiting for reply,
kpcta.
von Giovanni D. (gdisirio)
Ramesh Kumar wrote:
Hello, within my project I created a web demo using the AT91SAM7x256,
the demo uses an EMAC driver not related to the ATMEL code and it uses
both the transmit and receive interrupt sources.
I hope this can help.
http://chibios.sourceforge.net
The driver is under ./ports/ARM7-AT91SAM7x256
The demo works on an Olimex board that uses a Micrel PHY, the driver may
require small changes if your board uses a different PHY.
regards,
Giovanni
> Hello All,
> AT91SAM7x256.
> used for EMAC ISR.
> Waiting for reply,
> kpcta.
