Forum: ARM programming with GCC/GNU tools embedded web server for lpc2129
von Tiong L. (ctloh)
hi all..
i want to implement an embedded web server for lpc2129..can anyone
provide me some examples?
Tiong Loh wrote:
> hi all..
The LPC2129 has no ethernet support in hardware. If this controller has
to be used external hardware is needed. Feed google with CS8900,
DM9000E, ENC28J60, XPort or Wiznet to get an idea about the possible
options. There are many more but this should get you started. As an
alternative you may think about using AT91SAM7X or LPC23xx/24xx, both
offer ethernet-support in hardware but need an external PHY. Also check
the LuminaryMicro Stellaris controllers like the LM3S6965. The needed
software/firmware depends on the selected hardware.
Martin Thomas wrote:
> Tiong Loh wrote:
>> hi all..
Hi Martin Thomas,
I am actually using Olimex lpc-E2129,this board have ethernet
integrated.So,the hardware part should have no problems.Now i want to
implement a web server in the lpc2129 and a DS1620 temperature sensor as
a client so that the server can get the data from the temperature
sensor.i need to get all this done within this week,so it is kinda short
of time.can anyone help me on this?
Thanks..
> sensor.
- Ethernet-Software: http://www.freertos.org/portrowleylpc2124.html
- DS1620: so far I have not used such a device so I can not realy help.
But from description of the commumincation protocol in the datasheet
interfacing should not be difficult. For a first step try to interface
by "pin-toogle/pin-state-read" (and not using any LPC SPI hardware).
Once you have this working integrate the code into a FreeRTOS project as
a separate task which reads the temperature at a given rate. The reading
can be pushed into a queue and the web-server.task can pull it from the
queue to paste the value into the page-text created in
vProcessConnection.
Tough timeline.
>> sensor.
> vProcessConnection.
> Tough timeline.
What is the different between embedded web server and client actually?
If i already implement an embedded web client in my board,what should i
do to make the board as a embedded web server?
