Forum: ARM programming with GCC/GNU tools bootloader via USB
Author: Roman Mashak (romez777)
Hello,
I'm working on the bootloader, which is supposed to load image via USB.
It is AT91SAM7S256-based product. I've read Atmel's documentation and
reviewed the accompanied code.
So to test firmware I need to impement a simple user application (i.e.
Win32) to upload the image. I don't quite understand how to split the
image in to equal chunks, which will be sent over USB.
As I understood Atmel's documentation, only whole pages are burnt on
flash, i.e. I need to prepare set of chunks with size of page, correct?
But image size doesn't necessary be multiple, so there would be some
little piece remained.
Are there any ideas about that?
Thanks.
Author: Jonathan Dumaresq (dumarjo)
Roman Mashak wrote:
> Hello,
What is the driver you used on the USB ? CDC ?
You read a 256Byts and split them to the maximum size of the EP. I think
is 64 on SAM7 parts.
> flash, i.e.
Yeah your right.
The little piece remained will be filled with 0x00 or 0xff or anything
else. It doesn't matter.
> Thanks.
Hope this help
Jonathan
Jonathan Dumaresq wrote:
Thank you for your feedback.
Sorry for such a late reply. Things kept me busy.
Correct. I use CDC example form Atmel.
I don't quite understand here. Why do I read 256bytes and then divide to
the page size? What is EP, to be precise?
>> flash, i.e.
> Yeah your right.
Is it necessary to prepend every chunk with some header? I mean what is
the way to specify the first or last chunk in the stream?
