Forum: ARM programming with GCC/GNU tools mi_cmd_var_create: unable to create variable object
von Harold R. (hlritter)
Can anyone tell me what causes this error and how to get rid of it.
I get this when I attempt to debug my application. I run OpenOCD, launch
the debugger and come up at main(). Then any attempt to run to a break
point or step my code results in the error and I am unable to debug.
Thanks!
Harold
I have solved this one. If you have variables in your watch window that
you later eliminate from your code then attempt to debug again this
error is generated. The fix is to also delete the variable from the
watch list. At least this is how it works in Eclipse Europa.
Harold Ritter
> Thanks!
> Harold
von Dan Wheeler (Guest)
Confirmed.  Thank you.
