Forum: ARM programming with GCC/GNU tools Problems by using the PIT of the AT91SAM7XC
Author: Mark D. (Guest)
Hello,
I am a newbie and I try to use the PIT of the AT91SAM7XC. I am not sure
how to set bits of a register and so it could be possible that the
problem is located there. The aim of the following code is to switch on
the led clocked by an 1 ms signal caused by the PIT. The led does not
light up. Please help me:
 * Function Name       : configure_aic
static void configure_aic(void)
// Initialisierung des AICs
  // Deaktivieren aller AIC Interrupts
  AT91C_BASE_AIC->AIC_IDCR = 0xFFFFFFFF;
  // Löschen aller AIC Interrupts
  AT91C_BASE_AIC->AIC_ICCR = 0xFFFFFFFF;
// Konfiguration des Interrupts
  /* Ausschalten des Interrupts für Systemperipherie */
  AT91C_BASE_AIC->AIC_IDCR = (1 << AT91C_ID_SYS);
  /* Festlegen des Trigger-Modus und der Interrupt Priorität */
  AT91C_BASE_AIC->AIC_SMR[AT91C_ID_SYS] =
AT91C_AIC_SRCTYPE_INT_HIGH_LEVEL | AT91C_AIC_PRIOR_LOWEST;
  /* Einstellen des Source Vector Registers (enthält Adresse für
Interrupt Handler) */
  AT91C_BASE_AIC->AIC_SVR[AT91C_ID_SYS] = (unsigned long) pitc_handler;
  /* Einschalten des Interrupts am AIC */
  AT91C_BASE_AIC->AIC_IECR = (1 << AT91C_ID_SYS);
 * Function Name       : configure_pit
static void configure_pit(void)
  volatile unsigned long pimr = 0;
  /* Compare-Wert einstellen */
  AT91C_BASE_PITC->PITC_PIMR = 3000;
  /* Interrupt durch PIT zulassen */
  pimr = AT91C_BASE_PITC->PITC_PIMR;
  AT91C_BASE_PITC->PITC_PIMR = pimr | AT91C_PITC_PITIEN;
  /* PIT einschalten */
  AT91C_BASE_PITC->PITC_PIMR = pimr | AT91C_PITC_PITEN;
 * Function Name       : pitc_handler
void pitc_handler(void)
  unsigned long pivr = 0;
  unsigned long pisr = 0;
  /* Read the PISR */
  pisr = AT91C_BASE_PITC->PITC_PISR & AT91C_PITC_PITS;
  if (pisr != 0) {
    /* Read the PIVR. It acknowledges the IT */
    pivr = AT91C_BASE_PITC->PITC_PIVR;
    led_on();
 * Function Name       : led_on
void led_on(void)
  BASE_PIO_LED->PIO_CODR = LED_A;  // Switch on the led
 * Function Name       : main
int main()
  /* === AIC Konfiguration === */
  configure_aic();
  /* === PIT Konfiguration === */
  configure_pit();
  while(1)
Thanks for your help.
Best Regards
Mark
There is an example in the AT91SAM7X software-package (avail. from
atmel.com) for PIT on SAM7X
(getting-started-project-1.3-at91sam7x-ek.zip). Did you try to build and
run it?
