Forum: ARM programming with GCC/GNU tools ARM and XML stuff
von Rico Coco (Guest)
hello,
I'm quite new to arm devel and I know XML is very ressource demanding,
but I would like to know if it is possible to develop something for
parsing simple XML streams that would come from a TCP socket?
I'm using ARM GCC toolchain for Linux (build 2) with LWIP and FreeRTOS
I don't know where to start and if the newlib (1.14 ?) is enough to do
this ...
thanks for your help
Rico
von Clifford S. (clifford)
Rico Coco wrote:
> hello,
> this ...
> Rico
Try this http://expat.sourceforge.net/ it is written in C designed to be
portable, and is stream oriented, so should be easy to hook into a TCP
stream. Other than that I know nothing about it other than what is on
the web-site.
You might also Google on "Deeply Embedded XML Communication - Towards an
Interoperable and Seamless World" a whitepaper. All the available
sources require creating an account and logging in. It may be worth a
look.
Thanks Clifford for your reply,
I gonna have a look to all of this asap :-)
> the web-site.
> look.
