Forum: ARM programming with GCC/GNU tools USB-CDC code not working in KEIL
von Nanju M. (nanjooh)
Hi friends,
I am working in the KEIL uvision3 (Real view) tool.
Right now i am working in the USB-CDC programming for the AT91SAM7SE512
processor.
I have a example source code for AT91SAM7S64 processor in IAR workbench
tool.
Downloaded from
http://www.siwawi.arubi.uni-kl.de/avr_projects/arm_projects/index_at91.html
.This IAR code is working very well.
I want to  covert  the code from IAR  to keil tool for AT91SAM7SE512
processor.
The Problem is
1. when i connect the device to the host ( PC ),  I am getting the
message "USB device is not recognized".
2. can I include any files to this?
I have included the source code for your reference.
Could you please  advice me on this.
With Regards & Thanks,
Murthy.R
This might be a problem with struct-packaging. Did you check this? AFAIK
the Realview-compiler has a pragma to enable/disable packaging. There
are also USB examples included in the Keil-package (at least in an older
eval-version I have here) where you can see how the packaging can be
handled.
von Kris R. (2gatunek)
Do you resolve your problem ?
