Forum: ARM programming with GCC/GNU tools confused with GCC 4.2.2
Author: Toth Jozsef (joke)
Hello,
I was tried to compile my older project, but LD shows an error :
Linking: main/main.elf
arm-elf-gcc  -mcpu=arm7tdmi  -I. -g0 -DROM_RUN -DVECTORS_IN_ROM
-D__WinARM__  -Os -ffunction-sections -fdata-sections -Wall -Wcast-align
-Wimplicit  -Wpointer-arith -Wswitch -Wredundant-decls -Wreturn-type
-Wshadow -Wunused -Wa,-adhlns=
startup/Cstartup_source.lst  -I....... -fgnu89-inline -MD -MP -MF
.dep/.............   --output main/main.elf -nostartfiles
-Wl,-Map=./main/main.map,--cref,--gc-sections -lc  -lm -lc -lgcc
-lstdc++   -T./config/AT91SAM7S64-ROM.ld
c:/winarm/bin/../lib/gcc/arm-eabi/4.2.2\libgcc.a(unwind-arm.o): In
function `get_eit_entry':
../../gcc-4.2.2/gcc/config/arm/unwind-arm.c:464: undefined reference to
`__exidx_start'
`__exidx_end'
make: *** [main/main.elf] Error 1
older GCC was compiled fine these sources, but the 4.2.2 is not.
How to resolve this ?
regards
Do you use a arm-elf or arm-eabi build of the tools. Mind that the
latest test-version of WinARM still uses the prefix arm-elf but the
included tools are build with the arm-eabi. Please see
http://www.embedded.com/columns/technicalinsights/...
esp.  the lines at (29) in Listing 1.
Martin Thomas
Ok, I was copied the .ARM.exidx section into my linker script (that
based on your work :-) ). Now, the code has been compiled, but the code
length is zero :\
My linker script :
-----begin:
MEMORY
  CODE (rx) : ORIGIN = 0x00100000, LENGTH = 256k
  DATA (rw) : ORIGIN = 0x00200000, LENGTH = 48k
  STACK (rw) : ORIGIN = 0x0020c000,LENGTH = 16k
__FIRST_IN_RAM = ORIGIN(DATA);
/* Section Definitions */
SECTIONS
  /* first section is .text which is used for code */
  . = 0x0000000;
  .text :
    KEEP(*(.vectorg))
    . = ALIGN(4);
    KEEP(*(.init))
    *(.text .text.*)                   /* remaining code */
    *(.gnu.linkonce.t.*)
    *(.glue_7)
    *(.glue_7t)
    *(.gcc_except_table)
    *(.rodata)                 /* read-only data (constants) */
    *(.rodata.*)
    *(.gnu.linkonce.r.*)
    . = ALIGN(4);
  } >CODE
  . = ALIGN(4);
  /* .ctors .dtors are used for c++ constructors/destructors */
  .ctors :
    PROVIDE(_ctors_start_ = .);
    KEEP(*(SORT(.ctors.*)))
    KEEP(*(.ctors))
    PROVIDE(_ctors_end_ = .);
  } >CODE
  .dtors :
    PROVIDE(_dtors_start_ = .);
    KEEP(*(SORT(.dtors.*)))
    KEEP(*(.dtors))
    PROVIDE(_dtors_end_ = .);
  } >CODE
      /* .ARM.exidx is sorted, so has to go in its own output section.
    .ARM.exidx : {
        __exidx_start = .;
        *(.ARM.exidx* .gnu.linkonce.armexidx.*)
        __exidx_end = .;
    } >CODE
  . = ALIGN(4);
  _etext = . ;
  PROVIDE (etext = .);
  /* .data section which is used for initialized data */
  .data : AT (_etext)
  _data = . ;
  KEEP(*(.vectmapped))
  . = ALIGN(4);
  *(.fastrun .fastrun.*)
  . = ALIGN(4);
  SORT(CONSTRUCTORS)
  . = ALIGN(4);
  *(.data)
  *(.data.*)
  *(.gnu.linkonce.d.*)
  . = ALIGN(4);
  } >DATA
  . = ALIGN(4);
  _edata = . ;
  PROVIDE (edata = .);
  /* .bss section which is used for uninitialized data */
  .bss :
  __bss_start = . ;
  _bss_start_ = . ;
  *(.bss)
  *(.bss.*)
  *(.gnu.linkonce.b.*)
  *(COMMON)
  . = ALIGN(4);
  } >DATA
  . = ALIGN(4);
  _bss_end_ = . ;
  _end = .;
  PROVIDE (end = .);
  .int_data :
    *(.internal_ram_top)
  } > STACK
  /* Stabs debugging sections.  */
  .stab          0 : { *(.stab) }
  .stabstr       0 : { *(.stabstr) }
  .stab.excl     0 : { *(.stab.excl) }
  .stab.exclstr  0 : { *(.stab.exclstr) }
  .stab.index    0 : { *(.stab.index) }
  .stab.indexstr 0 : { *(.stab.indexstr) }
  .comment       0 : { *(.comment) }
  /* DWARF debug sections.
   Symbols in the DWARF debugging sections are relative to the beginning
   of the section so we begin them at 0.  */
  /* DWARF 1 */
  .debug          0 : { *(.debug) }
  .line           0 : { *(.line) }
  /* GNU DWARF 1 extensions */
  .debug_srcinfo  0 : { *(.debug_srcinfo) }
  .debug_sfnames  0 : { *(.debug_sfnames) }
  /* DWARF 1.1 and DWARF 2 */
  .debug_aranges  0 : { *(.debug_aranges) }
  .debug_pubnames 0 : { *(.debug_pubnames) }
  /* DWARF 2 */
  .debug_info     0 : { *(.debug_info .gnu.linkonce.wi.*) }
  .debug_abbrev   0 : { *(.debug_abbrev) }
  .debug_line     0 : { *(.debug_line) }
  .debug_frame    0 : { *(.debug_frame) }
  .debug_str      0 : { *(.debug_str) }
  .debug_loc      0 : { *(.debug_loc) }
  .debug_macinfo  0 : { *(.debug_macinfo) }
  /* SGI/MIPS DWARF 2 extensions */
  .debug_weaknames 0 : { *(.debug_weaknames) }
  .debug_funcnames 0 : { *(.debug_funcnames) }
  .debug_typenames 0 : { *(.debug_typenames) }
  .debug_varnames  0 : { *(.debug_varnames) }
------end
> length is zero :\
Try to add an ENTRY instruction to your linker-script. See line marked
with (3) in the mentioned listing.
>> length is zero :\
yes, now works :blush: :-)
thank you
Author: Tilo L. (katagia)
Maybe a silly question but what is the difference.
More detail: Why has it changed?
Cheers, Tilo
The "eabi" has been developed for binary compatibility. So you can use
for example a library ("lib-file") created with the Realview tools with
in a project which is developed with the arm-eabi GNU toolchain or IAR
EWARM 5.x and vice versa. A lot of information on the eabi can be found
on arm.com.
The current WinARM test-release (11/07) is a eabi-build which still uses
the arm-elf prefix to keep compatibility with older makefiles. It's just
for testing. My long-term plan (read: if I will ever have enough time)
is to modify and test all examples in the WinARM example-collection
for/with eabi so they can also be built with other precompiled arm-eabi
GNU toolchains like for example DevKitARM or Codesourcery's "G++ ARM
lite".
There are too many precompiled packages out there with small
differences. I think it's a good idea to get some common base so any
example created for a "bare metal" GNU ARM toolchain can be build with
any precompiled toolset. So it doesn't matter if the user has DevkitARM,
Sourcery G++, Idealist, Yagarto, GNUARM, Ride, Crossworks, WinARM or
whatever installed. I hope that the change to eabi is one step in this
direction.
