long long division
OP #1173363
• ▲ useful
▼ not useful
Hello,
I am trying to use long long division on ARM7 (LPC2103, LPC2129).
I wrote just a small program to test this something like:
int main(void)
volatile long long a,b,c;
a = b/c;
return 0;
If I try to compile this with the latest CodeSourcery tools 2007Q3,
the process failes with following output:
"-------- begin (mode: ROM_RUN) --------"
arm-none-eabi-gcc (CodeSourcery Sourcery G++ Lite 2007q3-53) 4.2.1
Copyright (C) 2007 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is
NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR
PURPOSE.
Compiling C: main.c
c:/tools/DEVEL/CodeSourcery\bin\arm-none-eabi-gcc -c  -mcpu=arm7tdmi
-I. -gdwarf-2 -DROM_RUN  -O1 -ffunction-sections -fdata-sections -Wall
-Wcast-align -Wimplicit  -Wpointer-arith -Wswitch -Wredundant-decls
-Wreturn-type -Wshadow -Wunused -Wa,-adhlns=main.lst  -I./INC
-Wcast-qual -MD -MP -MF .dep/main.o.d -Wnested-externs  -std=gnu99
-Wmissing-prototypes  -Wstrict-prototypes -Wmissing-declarations main.c
-o main.o
ECHO is off.
Linking: main.elf
c:/tools/DEVEL/CodeSourcery\bin\arm-none-eabi-gcc  -mcpu=arm7tdmi  -I.
-Wreturn-type -Wshadow -Wunused -Wa,-adhlns=startup.lst  -I./INC
-Wcast-qual -MD -MP -MF .dep/main.elf.d startup.o arm_exc.o
low_level_init.o bsp.o isr.o SysTick.o rprintf.o uart.o cmd_parser.o
m_string.o PWM.o debug.o ADC.o MotorDrive.o backup.o iap.o chksum.o
main.o     --output main.elf -nostartfiles
-Wl,-Map=main.map,--cref,--gc-sections   -Tblinky.ld
c:/tools/devel/codesourcery/bin/../lib/gcc/arm-none-eabi/4.2.1\libgcc.a(
unwind-arm.o):
In function `get_eit_entry':
unwind-arm.c:(.text+0x7a0): undefined reference to `__exidx_start'
unwind-arm.c:(.text+0x7a4): undefined reference to `__exidx_end'
c:/tools/devel/codesourcery/bin/../lib/gcc/arm-none-eabi/4.2.1/../../../
../arm-none-eabi/lib\libc.a(lib_a-abort.o):
In function `abort':
abort.c:(.text+0xc): undefined reference to `_exit'
../arm-none-eabi/lib\libc.a(lib_a-signalr.o):
In function `_getpid_r':
signalr.c:(.text+0x4): undefined reference to `_getpid'
In function `_kill_r':
signalr.c:(.text+0x2c): undefined reference to `_kill'
../arm-none-eabi/lib\libc.a(lib_a-sbrkr.o):
In function `_sbrk_r':
sbrkr.c:(.text+0x18): undefined reference to `_sbrk'
cs-make[1]: *** [main.elf] Error 1
If I add to linker scripts following lines:
        /* .ARM.exidx is sorted, so has to go in its own output section.
    .ARM.exidx : {
        __exidx_start = .;
        *(.ARM.exidx* .gnu.linkonce.armexidx.*)
        __exidx_end = .;
    } >ROM
 then the build failes with following output:
NO
PURPOSE.
ECHO is off.
Linking: main.elf
../arm-none-eabi/bin/ld.exe:
main.elf: warning: sh_link not set for section `.ARM.exidx'
The same process with latest yagarto tools (arm-elf-gcc version 4.2.2),
and no modifications in linker script, compiles without errors.
I need to use CodeSourcery tools. Does anybody have a clue what am I
missing?
Thank you in advance,
alessio
#1173364
• ▲ useful
▼ not useful
It looks like you have not implemented the necessary syscalls. Since the
code makes no library calls you might think that you need not do that,
but long long is not a fundamental machine type on ARM, so the compiler
may insert calls to functions for even basic operations on such a type.
That's my guess in any case; the use of long long and caused 64bit
support code to get linked, and that code includes the calls the linker
says are missing. The syscall stubs are target specific and need to be
implemented by you (or use/adapt one of the existing examples).
Clifford
OP #1173365
• ▲ useful
▼ not useful
Clifford, thank you for your reply.
I read about necessary syscall stubs in libm manual,
but didn't need them up until now. Can anybody please
give me some link where to start digging about those syscalls?
I am still curious why does the same program compile without errors
with yagarto arm-elf-gcc, but fails with CodeSourcery arm-none-eabi-gcc.
Built program with yagarto needs additional 1kB of space for long long
division and works OK.
The only difference between successful and unsuccessful compilation is
in makefile's COMPILER variable:
COMPILER = elf
ifeq ($(COMPILER),elf)
# GNU-ARM tools directory
GNU_ARM = c:/tools/DEVEL/yagarto
# The gcc compiler and linker
CC      = $(GNU_ARM)\bin\arm-elf-gcc
ASM     = $(GNU_ARM)\bin\arm-elf-as
LINK    = $(GNU_ARM)\bin\arm-elf-gcc
OBJCOPY = $(GNU_ARM)\bin\arm-elf-objcopy
SIZE = $(GNU_ARM)\bin\arm-elf-size
NM = $(GNU_ARM)/bin/arm-elf-nm
OBJDUMP =$(GNU_ARM)/bin/arm-elf-objdump
else
GNU_ARM = c:/tools/DEVEL/CodeSourcery
CC      = $(GNU_ARM)\bin\arm-none-eabi-gcc
ASM     = $(GNU_ARM)\bin\arm-none-eabi-as
LINK    = $(GNU_ARM)\bin\arm-none-eabi-gcc
OBJCOPY = $(GNU_ARM)\bin\arm-none-eabi-objcopy
SIZE = $(GNU_ARM)\bin\arm-none-eabi-size
NM = $(GNU_ARM)/bin/arm-none-eabi-nm
OBJDUMP =$(GNU_ARM)/bin/arm-none-eabi-objdump
endif
Regards,
alessio
#1173366
• ▲ useful
▼ not useful
This is because codesourcery build newlib (c library) with
--disable-newlib-supplied-syscalls whereas yagarto builds the default
system calls.
Also yagarto is a arm-elf toolchain, and the codesourcery is a arm-eabi
toolchain.
This syscalls interface did change slightly between the two aswell.
Cheers
Spen
OP #1173367
• ▲ useful
▼ not useful
> system calls.
> toolchain.
Spen, I greatly appreciate your helpful reply.
Can you say few words about what is the difference between arm-elf and
arm-eabi
toolchain? Do you have a link describing this, I have a lot more to
learn.
Cheers
#1173368
• ▲ useful
▼ not useful
> arm-eabi
> learn.
> Cheers
for standalone apps you may notice no difference.
It is really todo with a generic standard among targets/tools.
For example, if you built a library using Realview you should be able to
link it in with gcc source.
Have a look on arm website for lots of other info.
Cheers
Spen
(Company: student) #1446648
• ▲ useful
▼ not useful
> system calls.
Sorry for repling on this old post, but i want to say 'Thanks alot!' for
this clue. Im on this issue for the whole morning.
So as far as i know by now i need to implement the missing marks _sbrk,
_exit, _getpid and _kill bymyself. I'm pretty sure im not the only one
with this issue. Is there a implementation i can use for this? google
dont gives  matches about.
And i wonder if there is no way to just use a newlib with enabled
syscalls. I could just re-compile (not using installer) the codesourcery
w/o the disable option and use the built libc.a instead of my current.
I'm thankfull for any clue bout this.
Oh and bytheway im working on a cortex-m1
#1447262
• ▲ useful
▼ not useful
Read the "Building Bare-metal ARM with GNU" document in the ARM-GCC
development resources sticky thread (http://embdev.net/topic/129986)
Many of the syscalls are target/platform specific, which is why they are
not provided, they are what glue teh library you your specific
hardware.
In most cases you do not need to implement more than an empty stub, byt
_sbrk is critical since it enables dynamic memory allocation and heap
management.
(Company: student) #1447589
• ▲ useful
▼ not useful
I just implemented all of the missing references as stub function. Its
working. All i wonder is why my linker wants a reference to _sbrk. I
dont use functions useing memory allocation. The only "none-basic"
function is "memcpy" which is part of string.h, and from what i know it
dont use dynamic memory allocation. Another thing is this _getpid
mark... no idea why the linker needs it... whatever i implemented stubs
and its working.
If anyone got the same issue, just try out if simple stub functions are
working, it won't hurt.
Thanks for advice!
Please log in before posting.
or
Registration is free and takes only a minute.
Register now
