Where to find udivdi3 and umoddi3 in gcc?
OP #1173219
• ▲ useful
▼ not useful
Hello out there!
I am trying to compile, with uint64_t variables, diverse algorithms...
Getting error "undefined reference to `__udivdi3'"
Have been trying with math.h and trying  to find the strings udivdi3 and
umoddi3  in .h-files. No such luck!
Can someone help me, please?
Nils from Sweden
#1173220
• ▲ useful
▼ not useful
Nils Soderman wrote:
> Hello out there!
> Nils from Sweden
These are functions calls that the compiler generates to do 64bit
arithmetic operations (because they are not atomic instructions on a
32bit processor). The functions are provided by libgcc.a. You must
explicitly link this library if you have used the -nostdlibs option. You
do this with the linker option -lgcc.
Note that header files are not generally where functions 'live' they
usually merely declare functions. You need the declarations so the
compiler 'knows' hot to generate calls to them (and so it can check your
calls are valid). The functions you are having trouble with are
'internal' compiler helper functions, the code generator creates the
calls to them, for code like:
long long x = 10 ;
long long y = 3 ;
long long z = x / 3 ; // generates call to __udivdi3
Conceptually, no function is called, so no header is provided for
__udivdi3 etc. - you would not call them explicitly in your code.
Clifford
OP #1173221
• ▲ useful
▼ not useful
>> Hello out there!
>> Nils from Sweden
> long long x = 10 ;
> long long y = 3 ;
> Clifford
ThankYou Clifford, for your answer!
As can be seen in the attached makefile the linker is using the
libgcc.a. But still producing the error "undefined reference to
`__udivdi3'" and others!
My code:
#include "AT91SAM7X256.h"
#include "Board.h"
#include "stdio.h"
#include <math.h>
#include <stdarg.h>
#include <stdlib.h>
#include <inttypes.h>
void  CalculateDDSfractions ( UINT AD9834RefFrequency )
#define  help2to28times10  0xA0000000
  uint64_t  helpRefFq = AD9834RefFrequency;
  uint64_t  helpFraction;
  helpFraction = help2to28times10;
        helpRefFq /= 10;
        helpFraction /= helpRefFq;
  helpFraction /= ( helpRefFq / 10000000 );
Usuing UINT instead of uint64_t produces:
..linking
arm-elf-ld -v -Map main.map -Tlinkconfig_RAM.cmd -o main.out crt.o
main.o timerisr.o timersetup.o isrsupport.o lowlevelinit.o blinker.o
TWI_ctrl.o commands.o display.o HandleDDS.o menu.o buttons.o SPI_ctrl.o
eepromhandler.o a2dmodule.o Smeter.o
-L%,E:/Program/yagarto/lib/gcc/arm-elf/4.1.1/libgcc.a -lc
GNU ld version 2.17
HandleDDS.o: In function `CalculateDDSfractions':
F:\ARMdev\WorkSpaceSF4G\QROlleNG_RAM/HandleDDS.c:430: undefined
reference to `__udivsi3'
F:\ARMdev\WorkSpaceSF4G\QROlleNG_RAM/HandleDDS.c:431: undefined
make: *** [main.out] Error 1
Oh, I really want to solve this!
Best regards
Nils S
#1173222
• ▲ useful
▼ not useful
You need to link libgcc.a after libc.a since the libc.a has
dependencies on libgcc.a but not the other way around.
arm-elf-ld [...] -lgcc -lc [...]
An alternative is to use an linker iteration group:
arm-elf-ld [...] -( -lgcc -lc -) [...]
but this is less efficient and should rather be used to resolve circular
dependencies rather than as a substitute for simply getting the link
order correct.
One wonders why you need an explicit path for libgcc.a but not for
libc.a? -lgcc should be all that is necessary. And the "-L%" what is
that - an ill-formed macro not expanded perhaps?
Clifford
OP #1173223
• ▲ useful
▼ not useful
> order correct.
> Clifford
THANK YOU Clifford!
I changed the link command to :
  $(LD) $(LFLAGS) -o main.out $(OBJECTS) -L$(EXTRA_LIBDIRS) -lc -lgcc
which solved the problem! I found "-L%,$(EXTRA_LIBDIRS)" somewhere, have
been using it for a year!!!
Thank you again!
Best regards
Nils S
#1173224
• ▲ useful
▼ not useful
In a makefile, % is used as a wildcard for pattern matching. It is
difficult to see how it may have been intended to work here, but tha
fact that it appears in the output indicates that it has not been
expanded to anything useful. Make also has an automatic variable @%
defining "The target member name, when the target is an archive member."
according to the documentation. I am not sure what that means, but I
don't think that it is useful here either.
Note that posting the build log was the fastest way to get a definitive
answer (since my initial 'guess' was inaccurate).
Clifford
#1173225
• ▲ useful
▼ not useful
I just noticed something else about your original build log. You
specified the libgcc.a file in a -L option (presumably by way of the
EXTRA_LIBDIRS macro). -L specifies search paths for archives not the
archive itself. EXTRA_LIBDIRS in your case should be used only for
directories (folders) not the libraries themselves.
You either specify the archive alone with a fully qualified path or use
a -l (lower-case L) option to find an archive in any path specified by
-L. So you were never actually linking libgcc.a in any case, regardless
of the link order.
When using -l, the 'lib' prefix and '.a' extension are assumed - hence
-lgcc for libgcc.a.
Clifford
OP #1173226
• ▲ useful
▼ not useful
> of the link order.
> -lgcc for libgcc.a.
> Clifford
Thanks again!
makefile is like magic for me, me beeing mainly a hardware guy! But I
will learn...???
Best regards
Nils S
