Forum: ARM programming with GCC/GNU tools make doesnt work
von Jefy C. (jefy)
Hello,
When i use make at the command prompt, it says "make is not recognised
as internal or external command". Could anybody help me out with this.
Thanks,
Jefy
von Clifford S. (clifford)
You need to add the path to the \winarm\utils\bin folder to your PATH
environment variable. [Control panel->System->Advanced->Environment
variables]
Alternatively create a batch file c:\winarm\winarmvars.bat with the
following command:
PATH = c:\winarm\utils\bin;c:\winarm\bin;c:\winarm\arm-elf\bin;%PART%
And then create a program shortcut with the following target string:
%windir%\system32\cmd.exe /K c:\winarm\winarmvars.bat
This will create a command console with session specific environment
variables for WinARM.
There are of course endless variations of these approaches. You also nee
to modify the paths as necessary to match your installation.
Clifford
