Forum: ARM programming with GCC/GNU tools Visual Studio Configuration for GCC
Author: Amit Chatre (aseem)
     Currently I'm using a WinARM and its really user frendly for me.
But i want to know, How Visual Studio configure for GCC compiler to
build a ARM projects.
Please help me ...
Thanks in Advance.
Author: Jim Kaz (ancaritha)
Making Visual Studios use the GCC compiler is simple.  Create a Make
file for the ARM processor you are using.  Put it in the same folder as
your Visual Studios project file (or alternatively, you could look for
it via relative/absolute path).     When you are in Visual Studios,
right click on your project and go to Properties.  Go to the NMake tab
underneath Configuration Properties.  Change the following settings:
Build Command Line:      make
Rebuild All Command Line:    make rebuild_all
Clean Command Line:     make clean
If you did not create the makefile in the same folder as the project
file, replace "make" with the path to make.
Thank you Jim,
          I tried for it and its working.
          Thank you very much.
 Amit Chatre
