Forum: ARM programming with GCC/GNU tools AT91SAM7S256 SPI does not work
von Min G. (minge519)
Hi everyone,
I am trying to use AT91SAM7S256 SPI, butit does not work.
When I send data outof SPI port, I can not see any change on SPCK and
MOSI pins.
I use eclipse and SAM-ICE to debug on the AT91SAM7S-EK board.
I found when I read the SPI register in eclipse. All the register is 0.
The following are may SPI init code:
    AT91F_SPI_Reset     (AT91C_BASE_SPI);
    AT91F_SPI_Enable    (AT91C_BASE_SPI);
    AT91F_SPI_CfgMode   (AT91C_BASE_SPI, SPI_MSTR | SPI_FIX_SLCT |
SPI_CS_DIRECT | SPI_MODE_FAULT_DS | SPI_LOCAL_LOOP_DS | SPI_FIXED_CS_0);
    AT91F_SPI_CfgCs     (AT91C_BASE_SPI, 0, SPI_SCK_IDLE_LOW |
SPI_SCK_SAMPLE_RISING | SPI_CS_LOW_AFTR_TRANS | SPI_8_BITS_PER_TRANS |
(2*SPI_SCK_DIV_FACTOR));
    AT91F_PIO_CfgPeriph( AT91C_BASE_PIOA, // PIO controller base address
    ((unsigned int) AT91C_PA13_MOSI    ) |
    ((unsigned int) AT91C_PA31_NPCS1   ) |
    ((unsigned int) AT91C_PA14_SPCK    ) |
    ((unsigned int) AT91C_PA11_NPCS0   ) |
    ((unsigned int) AT91C_PA12_MISO    ), // Peripheral A
//    ((unsigned int) AT91C_PA9_NPCS1   ) |
//    ((unsigned int) AT91C_PA22_NPCS3   ) |
//    ((unsigned int) AT91C_PA3_NPCS3   ) |
//    ((unsigned int) AT91C_PA5_NPCS3   ) |
//    ((unsigned int) AT91C_PA10_NPCS2   ) |
//    ((unsigned int) AT91C_PA30_NPCS2   )
        0 ); // Peripheral B
Thanks. I am looking forward to every reply.
Min Ge
von Andreas S. (andreas) (Admin)
Min Ge wrote:
> Hi everyone,
> MOSI pins.
See page 253 in the datasheet:
"The SPI may be clocked through the Power Management Controller (PMC),
thus the programmer must first configure the PMC to enable the SPI
clock. "
Andreas S. wrote:
> Min Ge wrote:
>> Hi everyone,
>> MOSI pins.
> clock. "
I got it . It is working now. Thanks a lot.
Min Ge
von Nick M. (moszer)
Min Ge wrote:
> Andreas S. wrote:
>> Min Ge wrote:
>>> Hi everyone,
>>> MOSI pins.
>> clock. "
> Min Ge
I'm having a similar issue and (believe) I've followed the correct init
steps
After looking through the example and doc at
http://www.atmel.com/dyn/resources/prod_documents/doc6229.pdf
I have:
// Reset the SPI controller
// Configure PMC by enabling SPI clock
AT91F_SPI_CfgPMC ();
// Setup the SPI Mode Register
AT91F_SPI_CfgMode   (AT91C_BASE_SPI, MASTER | SPI_FIX_SLCT |
SPI_FIXED_CS_0);
// Setup the SPI Chip Select Register
// Setup the SPI Bus Pins
AT91F_SPI_CfgPIO ();
// Enable the SPI Bus
My defines are as follows:
#define SPI_FIX_SLCT            0   //Fixed Peripheral Select
#define SPI_CS_DIRECT      0   //Chip Select is directly connected
#define SPI_MODE_FAULT_DS    0   //Mode Fault Enabled
#define SPI_LOCAL_LOOP_DS    0   //Loop back disabled
#define SPI_FIXED_CS_0      0   //PCS = xxx0
#define SPI_SCK_IDLE_LOW    0   //CS idles low
#define SPI_SCK_SAMPLE_RISING    0   //Data is changed on the leading
edge of SPCK and captured on the following edge of SPCK.
#define SPI_CS_LOW_AFTR_TRANS    0   //The Peripheral Chip Select Line
rises as soon as the last transfer is achieved.
#define SPI_8_BITS_PER_TRANS    0  //8bit transfers
#define SPI_SCK_DIV_FACTOR    0x00003200
This is also on a AT91SAM7S256.
When I send data by writing to the SPI_TDR register the CS line never
goes low.  I checked the status register and it says the SPI bus is
enabled.  Anyone have any thoughts?  Any and all help is appreciated.
von Martin Thomas (Guest)
Maybe you can find some hints in my AT91-SPI interface for the Embedded
Filesystem Library (efsl) files src/interface/at91_spi.c) at
http://www.siwawi.arubi.uni-kl.de/avr_projects/arm_projects/efsl_arm/index.html
download the latest beta-version marked with [T4].
Martin Thomas
von Przemyslaw G. (pgp)
in my opinion it should be :
AT91F_SPI_CfgMode   (AT91C_BASE_SPI, AT91C_SPI_MSTR | SPI_FIX_SLCT<<1 |
SPI_CS_DIRECT<<2 | SPI_MODE_FAULT_DS<<4 | SPI_LOCAL_LOOP_DS<<7 |
SPI_FIXED_CS_0<<16 );
Don't forget to use Bitwise Operators !
