Forum: ARM programming with GCC/GNU tools misalignment access
Author: Alexander Khromykh (xelax)
I move the code from avr to arm. There is a problem: because of
architectures difference there are a lot of pieces into the code
where there is an access to misalignment addresses. ARM goes to data
abort mode.In Data abort interrupt in registers of Memory Controller
(MC)
I can look through the address of the last aborted access, abort size
status and abort type status. In order to finish access in bytes mode
for fullness of information there is lack of address where it is
necessary to write data (misalignment read) and address from where
data were written (misalignment write).
Where can I read these addresses? Is there a simple solution of this
problem?
P.S. at91sam7x256(atmel evalution board) + gcc4.2.1(yagarto)
> (MC)
> problem?
I am not sure what your question is. However to have ported code cause a
data abort it was probably wrong or at least unsafe and non-portable in
the first instance. You might post an example of the code in question so
you we might address the cause rather than the symptom.
Clifford
Author: Jim Kaz (ancaritha)
I had a problem with misalignment when writing to flash using the ARM
when I had no such issue on the AVR.  The AVR is an 8-bit processor, so
any address in range is a valid address to write to, but the ARMs are
32-bit, so when writing/reading to an address it has to be word aligned
(32-bit boundaries/multiples of 4).  If you are running in thumb mode it
must be half-word aligned (16-bit/multiples of 2).
Ah, that makes more sense. An ARM7 can perform 8 and 32bit addressing in
ARM mode and 8/16 in Thumb mode. I too had a problem once when a
hardware cost-down changed a 32bit data path to external Flash to 16bit.
In my case it was a simple matter of correctly setting the architecture
to ARM9 which has 8/16/32 bit addressing in ARM mode, but it stumped me
for a while - the Flash could not be programmed because the  programming
command sequence was being messed up by 16bit writes being compiled as
two 8 bit writes. I guess if I had not had an ARM9 the solution would
have been to do the Flash programming in Thumb mode.
